tuner board fault
  • psats
    • 823
    tuner board fault
    has any one opened there box as ive got tuner problem sat not finding channels
    the board that connects both tuners has a track broken
    i want to know if its supposed to be like that.
    its the track with the wire and diode to it at both tuners
  • max_gee
    • 108
    Its meant to be like that. Have a look at the psu board to see if the 470uf 10v cap is gone
    • psats
      • 823
      the cap has been replaced . the cable tuners working fine
      • max_gee
        • 108
        when you do a sat scan, connect a multi meter to the lnb out out and see if its switching the 2 voltages for H & V
        • psats
          • 823
          ive loaded a working chnll list from dream the signal showing on that 89%
          on the open its just shows 55%. 0 agc. 0 ber on all chnlls
          cant do voltage test till see my m8 at weekend.
          • max_gee
            • 108
            ok let us know how u get on
            • psats
              • 823
              did the voltage check today get no volts from the tuner
              looks like there no stronger than a clone dream version.
              • calisto
                • 37
                My cousins box has got the same thing but both his tuners have gone, the sat & cable side, re flashed both the sat & cable with new images but still the same, waitingfortime on the cable side & t moving to 13e on the at side but the motorised dish does not move, any ideas?
                Calisto
                • psats
                  • 823
                  Calisto
                  check the capicitors on the power board and the the main board see if they have blown you get rounded tops if they blow.
                  • calisto
                    • 37
                    Ok thanks, will check them out when get in from work.
                    Have you got a pic to know what I am looking for me please?
                    • psats
                      • 823
                      just check that the capacitors dont have a bulge on the top
                      you will notice a diffrence from the normal if blown.
                      • gtturbo
                        • 11
                        OKOKOKOKKOK
                        • babayborn
                          Tuner
                          Yeah, well done.
                          • GamezSearch
                            • 7
                            Had the same problem replacing C15 on the power board fixed it wahoooooo
