  1. Announcement:
    hacked accounts
    gmb45 (Admin Assistant)
    18th February, 2024
    12,715
  2. Announcement:
    Compromised/Hacked Accounts
    Johnner (Dufner)
    11th February, 2024
    12,131
Page 1 of 41 12345611 ... LastLast
Threads 1 to 30 of 1229
Forum: Help and Discussion
  1.   Sticky Threads
  2. Sticky Thread Sticky: >>>>>>>>>>>>>>>>>>>>>>>>> AUTODATA <<<<<<<<<<<<<<<<<<<<<<<<<
    Started by PremierD, 30th December, 2010 08:14 PM
    30th December, 2010, 08:14 PM Go to last post
  3.   Normal Threads
  1. VGS2-FCVT MERCEDES B
    Started by ares12, 19th April, 2024 06:13 PM
    19th April, 2024, 06:13 PM Go to last post
  2. Code for Philips 22DcC 579/62 please
    Started by Jiult, 12th April, 2024 11:18 AM
    12th April, 2024, 11:18 AM Go to last post
    8th April, 2024, 09:36 AM Go to last post
  3. Caterpillar flash files
    Started by spakos, 22nd April, 2010 10:15 PM
    100 Pages
    1 2 3 ... 100
    25th March, 2024, 11:45 AM Go to last post
  4. foxflah work with tractor and harvester CLAAS
    Started by plam1972, 20th February, 2024 06:30 PM
    9th March, 2024, 06:51 PM Go to last post
    5th March, 2024, 04:34 PM Go to last post
    26th February, 2024, 03:59 PM Go to last post
  5. Deutz EDC17CV52 EGR , DPF and SCR
    Started by Escort, 13th December, 2023 09:31 PM
    23rd February, 2024, 11:20 AM Go to last post
  6. global tis activation
    Started by 12manux, 22nd July, 2020 04:00 PM
    2 Pages
    1 2
    21st February, 2024, 08:40 PM Go to last post
  7. plz i need code the activation for ista 4.37
    Started by mestour, 18th February, 2024 07:49 AM
    18th February, 2024, 07:49 AM Go to last post
  8. Claas Scorpion 7044 hours
    Started by bendix2, 24th August, 2021 12:27 PM
    13th February, 2024, 10:23 AM Go to last post
  9. Help abs fault in l405 vogue range rover issu
    Started by uchtool, 12th February, 2024 06:25 AM
    12th February, 2024, 06:25 AM Go to last post
  10. Renault Megane 3 air conditioning problem
    Started by Gferi, 18th January, 2024 07:08 PM
    10th February, 2024, 02:26 AM Go to last post
  11. Servo motor drive A06B
    Started by fejlong, 6th January, 2024 11:19 AM
    28th January, 2024, 08:31 PM Go to last post
  12. JD AL211166 EEPROM Dump
    Started by maschinist, 25th January, 2024 01:01 PM
    25th January, 2024, 01:01 PM Go to last post
  13. Insite 8.9 need please
    Started by Ferozk474, 25th January, 2024 07:24 AM
    25th January, 2024, 07:24 AM Go to last post
  14. cummins insite 8.9,inpower14,calterm4.7
    Started by zhangbaochen, 10th October, 2023 03:53 AM
    25th January, 2024, 07:03 AM Go to last post
  15. BMW G30 530 HYBRID
    Started by dimon1984, 21st January, 2024 07:02 AM
    21st January, 2024, 07:02 AM Go to last post
  16. DEUTZ 5120 3.6L 87kW/116HP, Backup or EEprom needed
    Started by Roberto 68, 15th October, 2022 02:29 PM
    17th January, 2024, 04:21 PM Go to last post
  17. Detroit, Cummins and Volvo USA DEF Delete Instructions
    Started by Biggame520, 28th December, 2023 12:35 AM
    28th December, 2023, 11:23 PM Go to last post
  18. Hino 5 pin diagnostic
    Started by Electronics27, 16th November, 2023 07:27 AM
    16th November, 2023, 07:27 AM Go to last post
  19. ISO ECFG FILE FOR L9 CM2350A
    Started by perfautotech, 11th November, 2023 01:28 AM
    bie ecfg, cm2350, cummins bie, qsl8.9 cm2350 ecfg
    11th November, 2023, 01:28 AM Go to last post
  20. Easy Renault 0.0.11 wanted.
    Started by Kurtkoeln, 1st November, 2023 06:16 PM
    1st November, 2023, 06:16 PM Go to last post
  21. Scania - Battery power supply - help
    Started by jo?o antonio, 29th October, 2023 08:03 PM
    29th October, 2023, 08:03 PM Go to last post
  22. VOLVO D13 hard to find feeler gauges
    Started by ajp123, 29th October, 2023 03:04 PM
    29th October, 2023, 03:04 PM Go to last post
  23. cummins insite 8.9
    Started by zhangbaochen, 22nd October, 2023 06:44 AM
    22nd October, 2023, 06:44 AM Go to last post
  24. Nissan MEC34-023 pinout
    Started by Daams13, 17th October, 2023 06:22 PM
    17th October, 2023, 06:22 PM Go to last post
  25. Eaton Service Ranger 3.2
    Started by gwdsike, 16th October, 2023 03:04 AM
    16th October, 2023, 03:04 AM Go to last post
  26. FLS file from hydraulic ecu CAT 277B to bin
    Started by milzal, 13th October, 2023 10:06 AM
    13th October, 2023, 10:06 AM Go to last post
  27. EMR1 Deutz ecu file needed.
    Started by dany_l2003, 7th October, 2023 11:33 AM
    7th October, 2023, 11:33 AM Go to last post
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 10 replies or 100 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
