  1. Announcement:
    Compromised/Hacked Accounts
    Johnner (Dufner)
    11th February, 2024
    16,460
Page 11 of 1419 FirstFirst ... 67891011121314151621611115111011 ... LastLast
Threads 301 to 330 of 42558
Forum: ECU
  1. ford dcm6.1 pinout eprom 25lc256
    Started by hudy26, 10th April, 2022 09:05 PM
    2 Pages
    1 2
    7th May, 2024, 03:09 PM Go to last post
  2. PSA DCM7.1A Foxflash!
    Started by khaleddaddi, 6th May, 2024 08:48 AM
    7th May, 2024, 01:55 PM Go to last post
  3. BMW X3 EDC16C35 Immo Off / Virgin
    Started by Wade123, 7th May, 2024 08:31 AM
    7th May, 2024, 01:07 PM Go to last post
  4. VW Tiguan ABS codig help
    Started by marcin7091, 1st July, 2019 03:33 PM
    7th May, 2024, 12:39 PM Go to last post
  5. VW TIGUAN 2009 abs coding
    Started by Stevens Ferreira, 10th September, 2019 04:52 PM
  6. VW Tiguan ABS coding help
    Started by hackero, 13th December, 2021 04:28 PM
    7th May, 2024, 12:38 PM Go to last post
  7. MEC32-211
    Started by tes, 7th May, 2024 11:53 AM
    7th May, 2024, 11:53 AM Go to last post
  8. fiat fiorino crash blocked fuel pump relay
    Started by prosec, 1st August, 2013 02:34 PM
    7th May, 2024, 07:51 AM Go to last post
  9. VIRGIN ECU RENAULT SAGEM S2000 RPM
    Started by drupal, 1st May, 2024 11:55 PM
    7th May, 2024, 06:21 AM Go to last post
  10. SID807EVO DS5 VIRGIN
    Started by rex89, 11th August, 2020 08:24 PM
    6th May, 2024, 07:07 PM Go to last post
  11. Ktflash experience reading E78 ECM
    Started by keycutters, 4th May, 2024 04:45 PM
    6th May, 2024, 02:56 PM Go to last post
  12. Hyundai sim2k 251 need dtc off p0011
    Started by Noumanshah8633, 6th May, 2024 12:44 PM
    6th May, 2024, 12:44 PM Go to last post
  13. Simos PCR2.1 unlock needed
    Started by brfbrf33, 5th May, 2024 06:43 PM
    6th May, 2024, 12:29 PM Go to last post
  14. Toyota Dyna 1KD 89663-25321 DPF solution
    Started by viktor0221, 6th May, 2024 10:18 AM
    6th May, 2024, 10:18 AM Go to last post
  15. URGENT ECU PHOTO, DIAGRAM ,
    Started by bursuc, 21st December, 2011 02:09 PM
    6th May, 2024, 09:15 AM Go to last post
  16. ECU Repair Helper E-Book [2023] link work
    Started by drupal, 5th May, 2024 10:11 PM
    5th May, 2024, 10:11 PM Go to last post
  17. Teansit connect pscm u3000
    Started by Hunter1206, 5th May, 2024 08:53 PM
    5th May, 2024, 08:53 PM Go to last post
  18. opel antara dcm3.7 cloning information
    Started by ASCM, 5th May, 2024 07:30 PM
    5th May, 2024, 07:30 PM Go to last post
  19. EDC17CP18 DPF / SCR Warning delete solution needed
    Started by GeorgeGG, 5th May, 2024 06:02 PM
    5th May, 2024, 06:02 PM Go to last post
  20. FILE ORIG TOYOTA AURIS NEEDE
    Started by shouari, 4th May, 2024 11:44 PM
    4th May, 2024, 11:44 PM Go to last post
  21. Need Bmw e60 2.5D full backup
    Started by mersytis, 4th May, 2024 09:25 PM
    4th May, 2024, 09:25 PM Go to last post
  22. PEUGEOT 3008 1.2 PUROTEC130HP ERR0R P1032-66
    Started by technoparc, 2nd May, 2024 08:56 PM
    4th May, 2024, 06:00 PM Go to last post
  23. Jumper SID208 virgin
    Started by matrixs11, 4th May, 2024 10:59 AM
    4th May, 2024, 04:05 PM Go to last post
  24. BMW E88 - NOX delete
    Started by felipeuk12, 4th May, 2024 01:30 PM
    4th May, 2024, 01:30 PM Go to last post
  25. Fiat Palio 1,2 16v Bosch ecu 0261207488 me73H4F007
    Started by carprog42, 4th November, 2013 06:22 PM
    4th May, 2024, 12:05 PM Go to last post
  26. Bmw e90 frm3 fixed but problem remains help
    Started by Nazo, 1st May, 2024 09:23 AM
    4th May, 2024, 07:30 AM Go to last post
  27. MSD80 to MSD81
    Started by EEpromDestroyer, 1st May, 2024 10:34 PM
    4th May, 2024, 01:08 AM Go to last post
  28. Lancia Delta 1.6 Jtd EDC17C49
    Started by anotherday15, 17th August, 2023 02:01 PM
    3rd May, 2024, 09:54 PM Go to last post
  29. Ducato 2.3jtdm remove fault U0100
    Started by denis1hr, 3rd May, 2024 08:17 PM
    3rd May, 2024, 08:17 PM Go to last post
  30. clio df002
    Started by jasu73, 3rd May, 2024 04:15 PM
    3rd May, 2024, 05:03 PM Go to last post
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 10 replies or 100 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
