  1. Announcement:
    Compromised/Hacked Accounts
    Johnner (Dufner)
    11th February, 2024
    16,132
Page 2 of 1417 FirstFirst 123456712521025021002 ... LastLast
Threads 31 to 60 of 42502
Forum: ECU
  1. dcm 3.7 ap dpf and egr delete
    Started by shawejeff, 28th May, 2024 12:23 PM
    28th May, 2024, 08:27 PM Go to last post
  2. DIMSPORT ECU Pinout Connection
    Started by sakin, 10th October, 2023 09:28 PM
    11 Pages
    1 2 3 ... 11
    28th May, 2024, 06:43 PM Go to last post
  3. Ren Master sid310 ori search
    Started by sepistar, 28th May, 2024 05:07 PM
    28th May, 2024, 05:07 PM Go to last post
  4. Dtc Off Nissan Qachqai
    Started by electop, 28th May, 2024 01:06 PM
    28th May, 2024, 02:39 PM Go to last post
    28th May, 2024, 01:38 PM Go to last post
  5. Opel Insignia 1.6T [A16LET] no power after engine swap..
    Started by WinWoj, 12th April, 2017 03:14 PM
    28th May, 2024, 01:08 PM Go to last post
  6. KIA SORENTO DTC OFF EDC17C53
    Started by ELETTRA64, 28th May, 2024 12:17 PM
    28th May, 2024, 12:17 PM Go to last post
    28th May, 2024, 11:59 AM Go to last post
  7. TOYOTA CAMRY ECU ENGINE ECU, AHV40, 2.4, HYBRID
    Started by ars1, 28th May, 2024 10:40 AM
    28th May, 2024, 10:40 AM Go to last post
  8. ssangyong rexton egr
    Started by mattiamatty, 15th March, 2021 08:10 PM
    28th May, 2024, 06:56 AM Go to last post
  9. Default EcusDataSheet 2.0
    Started by anks, 9th September, 2023 02:59 PM
    2 Pages
    1 2
    28th May, 2024, 05:16 AM Go to last post
  10. TCM VAG 01m 927 733 ** original files
    Started by hesham10, 15th February, 2019 01:27 AM
    4 Pages
    1 2 3 ... 4
    28th May, 2024, 05:11 AM Go to last post
    28th May, 2024, 05:10 AM Go to last post
  11. FIAT EVO 1.3 WITH START& STOP DOESN'T CHARGE THE BATTERY
    Started by Panathaole, 5th September, 2020 09:06 AM
    28th May, 2024, 03:00 AM Go to last post
  12. Opel astra G Cel16sel Replacement Problem
    Started by Nazo, 9th April, 2024 09:15 PM
    27th May, 2024, 09:48 PM Go to last post
  13. Ford connect sid 206
    Started by davorOS, 27th May, 2024 08:57 PM
    27th May, 2024, 08:57 PM Go to last post
  14. ECU MODULES REPAIR HELPER Free
    Started by 98secret, 8th August, 2022 05:59 PM
    27th May, 2024, 06:47 PM Go to last post
  15. EDC17C60_Tprot_Immo_removal
    Started by ZINE DDINE, 26th April, 2024 10:35 AM
    27th May, 2024, 05:20 PM Go to last post
  16. Virginize s3000
    Started by shouari, 27th May, 2024 05:15 PM
    27th May, 2024, 05:15 PM Go to last post
  17. Master 2017 EDC17C42 Data correction/virginise help
    Started by mak2001, 27th May, 2024 04:00 PM
    27th May, 2024, 04:00 PM Go to last post
  18. 0281012113 A6 Automatic Transmition Ori File
    Started by atalayyildiz, 27th May, 2024 01:43 PM
    27th May, 2024, 01:43 PM Go to last post
  19. Please original file for RAV 4, 89661-42A10
    Started by bmw325, 11th November, 2022 02:25 PM
    27th May, 2024, 12:14 PM Go to last post
  20. Volvo full flash
    Started by doloman, 27th May, 2024 11:35 AM
    27th May, 2024, 11:35 AM Go to last post
  21. Opel Omega B Simtec 56 immo off
    Started by Ginocar, 1st August, 2022 02:53 PM
    27th May, 2024, 08:38 AM Go to last post
  22. Peugeot 508 2.0 HDI DPF + ADBlue Off Please!!!
    Started by 076458C, 25th May, 2024 02:37 PM
    27th May, 2024, 07:33 AM Go to last post
  23. Bmw E 87 1.6i Lambda off please
    Started by Kogen11, 24th May, 2024 03:06 PM
    27th May, 2024, 01:30 AM Go to last post
  24. Audi Q5 8k0953502BK Steering angle sensor fault
    Started by Gladi77, 26th May, 2024 08:06 PM
    27th May, 2024, 12:32 AM Go to last post
  25. Ford transit 2.4 tddi PCM
    Started by kayo91, 24th May, 2024 01:01 PM
    26th May, 2024, 09:24 PM Go to last post
  26. Dacia Logan II. 1.0 EMS 3125 cat off
    Started by talazso, 26th May, 2024 01:51 PM
    26th May, 2024, 07:43 PM Go to last post
  27. PASSAT 2001 ABS CODING
    Started by gifret, 26th May, 2024 03:51 PM
    26th May, 2024, 05:03 PM Go to last post
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 10 replies or 100 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
