Dear Technical Support
  • firestorm
    • 1550
    Dear Technical Support,
    18 months ago, I upgraded to Girlfriend 1.0 from DrinkingMates 4.2, which I had used for years without any trouble. However, there are apparently conflicts between these two products and the only solution was to try and run Girlfriend 1.0 with the sound turned off.
    To make matters worse, Girlfriend 1.0 is incompatible with several other applications, such as LadsNightOut 3.1, Football 4.5, and Playboy 6.9. Successive versions of GirlFriend proved no better.
    I tried a shareware program, Slapper 2.1, but it had many bugs and left a virus in my system, forcing me to shut down completely for several weeks. Eventually, I tried to run GirlFriend 1.2 and Girlfriend 1.0 at the same time, only to discover that when these two systems detected each other they caused severe damage to my hardware.
    I eventually upgraded to Fianc?e 1.0, only to discover that this product soon had to be upgraded further to Wife 1.0. While Wife 1.0 tends to use up all my available resources, it does come bundled with FreeSexPlus and Cleanhouse2005.
    Shortly after this upgrade, however, I found that Wife 1.0 could be very unstable and costly to run. Any mistakes I made were automatically stored in Wife 1.0's memory and could not be deleted. They then resurfaced months later when I had forgotten about them. Wife 1.0 also has an automatic Diary, Explorer and E-mail filter, and can, without warning, launch TurboStrop and Multi-Whinge. These latter products have no Help files, and I have to try to guess what the problem is. Additional problems are that Wife 1.0 needs updating regularly, requiring ShoeShop Browser for new attachments and Hairstyle Express which needs to be reinstalled every other week. Also, when Wife 1.0 attaches itself to my Saab93 Convertible hard drive, it often crashes. Wife 1.0 also comes with an irritating pop-up called MotherInLaw, which can't be turned off.
    Recently I've been tempted to install Mistress 2005, but I've been told there could be problems. A friend of mine has alerted me to the fact that if Wife 1.0 detects Mistress 2005, it tends to delete all of your Money before uninstalling itself.
    Any advice would be helpful, many thanks.
  • darrenhyland
    • 1124
    Re: Technical inquiry....
    Hello,
    Sorry to hear you are experiencing these issues but unfortunatley this is a common issue that can end in complete system failure.......but dont despair as we do offer a solution to this issue called Dualbed1.0......it is simple but can be expensive....heres how it works:
    ....keep wife 1.0 happy by installing creditcard1.0 in her OS
    Install Affair2.0 on the same hard drive but under a different OS sush as Ubangedwho.....now you have a dualbed system but please remember DO NOT run any associated programmes of Wife1.0 under the other OS....programmes such as Sisterinlaw1.0 will work for a while but when detected by Wife1.0's routine system checker then the result will be catastrophic system failure.
    Hope this helps.
    Microhardon Corp.
    Tools owned..... Kess3 Master, Bitbox, TGFlash, VVDI2 Full, VVDI Prog, VVDI MB Tool, VVDI Mini Tool, VVDI Key Tool Max Pro, VCX series for BMW Ford Mazda Jaguar Land rover VAG Toyota Volvo GM, PCM Flash + Scanmatik2, Lonsdor K518ise, Magic tank and every other piece of Chinese crap out there.
