Dreamplug
  • SouthernComfort
    • Feb 2011
    • 403
    Dreamplug
    Just found out about these things and must say I'm very impressed, basically it's a fully portable debian server, the size of a power pack, too much info to list in one post but recommend a bit of reading for anyone interested.
    The ?DreamPlug? is a small robust product which draws under 5 watts of power, and can handle the most demanding of tasks. even with no internal moving components, ensures efficient heat dissipation in the most challenging conditions.
    Specification:
    Marvell Sheeva core 1.2GHz speed
    Linux 2.6.3x Kernel
    512MB 16bit DDR2-800 MHz
    2 GB on board micros-SD for kernel and root file system
    2 x Gigabit Ethernet 10/100/1000 Mbps
    2 x USB 2.0 ports (Host)
    1 x eSATA 2.0 port -3Gbps SATAII
    1 x SD socket for user expansion/application
    WiFi 802.11 b/g
    Bluetooth BT2.1 + EDR
    Audio Interfaces
    Headphone (analogue) out x 1
    Mic In
    Fiber Optics (SP/DIF) out x 1
    Jtag and Uart connections for external module
    5V3A DC power supply.
    Physical Dimensions:
    120mm (L) x 90mm (W) x 30mm (H)
    More info
    DreamPlug
    PlugWiki
    "What we've got here is failure to communicate."
