Help and info on E-Cigarette / e-cigs
  • tshirtman
    • 1345
    #196
    thats the same supplier I use for PG
    500ml MPG Propylene glycol USP/EP 99+% Pharma grade better then food grade | eBay
    VG: Vegetable Glycerine - Food/Kosher Grade - 1000ml | eBay
    and there's a link for nicotine on my earlier post.
    !retupmoc eht ni deppart m'I !pleH
    • dik
      • Apr 2009
      • 955
      #197
      Vg works out cheaper in boots it's 89p for 200ml and no postage, also their menthol crystals are only penny's too
      sigpic another happy customer
      Sent from my keyboard using fingers to type
      • smirnoff_rules
        • 8603
        #198
        Originally posted by dik
        here's a link for the pg, get your vg and menthol crystals from boots
        Here's a link for cheap nic juice - 30 ml of 75 mg/ml #100400022
        Although I buy the larger sizes
        cheers lads for clearing that up
        l have ordered that juice from ebay and the nic and menthol from nicvap , so l have the 3 items to make my own and have a play cheers
        and l can use this calculator Cloud 9 Vaping E-Liquid Mixing Calculator - Cloud 9 Vaping
        so if making 30ml bottle its works like this ? that right lads
        • tshirtman
          • 1345
          #199
          No m8
          you will average 20 drops per ml, you've only got 5 drops per ml
          with my calculator, on your preference I get: (I've worked it out at a PG/VG ratio of 40/60)
          nicotine - 7.2ml - 144 drops
          PG - 1.8ml - 36 drops
          VG - 18ml - 360 drops
          flavouring - 3ml - 60 drops
          that's with the nicotine having a PG base.
          • dik
            • Apr 2009
            • 955
            #200
            I find it easier to use ml's not drops get a 5ml syringe from boots put Sellotape over the markings to stop them wearing off in minutes! Vg is very thick so drops are massive, if using pg nic base and flavourings as well as adding pg to your mix there's no need to thin the vg
            • dik
              • Apr 2009
              • 955
              #201
              The ejuicemeup calculator allows many more options than most take a look lads
              • Shady
                Shite Link King
                • Dec 2010
                • 6404
                #202
                well, well, well, this is turning out to be quite a busy little thread.
                Now ive long said that dk'ers are the best people to go for for advice on most things, and as this thread proves, a lot of dk'ers are liking these efags..
                so a couple of q's if i may;
                1: Do you still want a proper fag? or are they a complete alternative?
                2: Do you get that same sweet, sweet warmth hitting the back of your throat and filling your lungs with feelings of rainbows and puppies?
                cos, me, im willing to give anything a go, and i will blindly follow anything dk'ers say is good.
                • dik
                  • Apr 2009
                  • 955
                  #203
                  shadyback Not everyone manages to quit the fags straight away, lots use them to just cut down and gradually move over to e fags, for me I quit straight away with only 2 fags in the first couple of days, but when you find the right juice, right method of vaping it and the right voltage to hit your "sweet spot" (for me it's 4volts with a 2.8 ohm resistance coil in a clockworks rta filled with grizwalds caramel cappuccino 20mg nic juice mounted on a lavatube) it's bloody heaven, beats the best fag hands down.
                  I'm never giving these up and don't miss the fags one bit, some find it harder at first due to missing the tobacco alkaloids (can now be added to juices) and the brain being starved of oxygen from inhaling carbon monoxide - you could try strangling yourself to simulate that!, it's a lot of trial and error to find what suits you best treat it like a new hobby, it'll cost at least the same & possibly a lot more than smoking at first but once you're set up costs will come way down, and the way your lungs feel after a couple of months makes the initial outlay and hassle well worth it, there's also the massive bonus of being able to vape wherever smoking is banned
                  • Shady
                    Shite Link King
                    • Dec 2010
                    • 6404
                    #204
                    meaty?
                    see thats the sort of thing putting me off.. lets start off easy shall we? recommendations for best starter kit please gents
                    • dik
                      • Apr 2009
                      • 955
                      #205
                      ok m8 you cant go wrong with one of these 510 Tank Dual Coil Cartomizer With eGo -T Manual Battery Black (900mah) - ecigvapors.co.uk / Zarnas Vaping, E cigarette Shop
                      then you will need a usb charger, maybe a wall adapter for the charger and it's useful to have a spare battery (items 1,3 & 5
                      eGo -T Accessories - ecigvapors.co.uk / Zarnas Vaping, E cigarette Shop
                      then you will need some juice (for a 20/30 a day smoker get the 20mg nicotine strength) Grizwald's Mega Mix ***163;24.99 - Grizwald's Gourmet Range - Pick 'n' Mix Electronic Cigarettes | Vaping Devices | Accessories | E-Liquid
                      and some spare cartomisers (the disposable bit that goes in the tank) get 1.5 ohm ones expect each one to last a week
                      1.25ohm CHALLENGER TANK DUAL COIL CARTOMIZER
                      • smirnoff_rules
                        • 8603
                        #206
                        if u want something to just start off l cant fault these m8 , price looks high but u get 2 of everything and carts have lasted me 4 weeks and still going , the vap is ace and l havnt had 1 single fag in that time m8 , we all love to play on here and its another toy , l run 45 minutes every day and since starting these l do an hour and chest feels great again , not a single cough since l started
                        this is wot im using APL-A580 New product for Safercigs
                        [ame="http://www.youtube.com/watch?v=M8DHrspO-dE&feature=player_embedded"]APL-A580. - YouTube[/ame]
                        [ame="http://www.youtube.com/watch?v=TyoI7QC5n1Q"]APL-A580 atty fill.wmv - YouTube[/ame]
                        • tshirtman
                          • 1345
                          #207
                          they really do work mate, when I got mine, the other half was having a go at me, saying more money wasted on gadgets, then she wanted a go,
                          she soon changed her mind, now she uses one as well, and we have both quit.
                          I admit I didn't quit the fags completely at first, but have now.
                          as for the question about the feeling in the back of the throat and lungs, it's just the same as fags,
                          you get the kick at the back of the throat, then the warm feeling in the chest, and plenty of vapor like a real cig,
                          but there's no tobacco smell, and you just take as many pulls on it till you feel like you've got enough nicotine in your system.
                          There is a bit of trial and error at first, finding the right flavour and nicotine strength, and there's 100s of flavours,
                          you can get some really weird ones like, curry, absinth, garlic bread, parma violets.
                          I'm currently using a premixed juice called Plutonium Ice, and I love it, funny thing is, I cant stand menthol cigs, but this hits the spot.
                          • smirnoff_rules
                            • 8603
                            #208
                            why do these only last this long ,, ?
                            • tshirtman
                              • 1345
                              #209
                              because the attomiser element burns out, that's why the repairable attomisers are becoming more common,
                              I've been looking at the bulli - smoker A1
                              > A2 Klassik <, 45,00 &euro; (German site)
                              English video - [ame=http://www.youtube.com/watch?v=uYOHYdNqiks]REVIEW OF THE BULLI A2-T REPAIRABLE ATOMISER - YouTube[/ame]
                              • smirnoff_rules
                                • 8603
                                #210
                                English video - REVIEW OF THE BULLI A2-T REPAIRABLE ATOMISER - YouTube
                                if these start letting me down APL-A580 ATOMIZERS l will look into these , look great to and will fit my 580 batters too
