Help and info on E-Cigarette / e-cigs
  • stanburyfam
    • Nov 2011
    • 12
    #241
    Thanx guys will carry on for now but lloking at all the self filling posts it seems very interesting and cheaper..When I am more into it will definately start going in this direction but for now will just concentrate on staying away from the tobbaco..Thanx again..Jay
    • smirnoff_rules
      • 8603
      #242
      Originally posted by dik
      Oksmoky's (E-liquid 50ml - E-Cig Liquids) roll up tobacco juices are very good for those just moving from smoking, I now don't like the fag flavours apart from cherry tobacco with a little menthol, now I mostly vape grizwalds caramel cappuccino. A must have tool is the spikey thing from cigeliquid
      (spiky refiller) fits on a juice bottle and gets rid of the need for a syringe
      @smirnoff I just bought a apl 580 for a friend and they love it
      tell your m8 the atty works and last longer using clear fluid m8 .. thats wot l have learned over the month , coloured ones seem to give a burned taste after abit but u can strip down and clean easy and there fine again and a few dry burns to
      just ordered these for it , will test with the 580 battery and review them for u http://www.safercigs.co.uk/Dual_Coil...3_3940739.aspxjust tried these attys and it kills the battery fast m8 ,, looking for a cheap vv now if anyone seen any about
      • dik
        • Apr 2009
        • 955
        #243
        You can refill the carts that you have a few times with e juice, you just fill the silicon cap that comes with them with e juice and stand the cap on a table and push your cartomiser/filter into it, then if you over fill just blow it through into a tissue & re connect back to battery and vape. Do a search for cartomiser filling condom method
        sigpic another happy customer
        Sent from my keyboard using fingers to type
        • smirnoff_rules
          • 8603
          #244
          just ordered these for it , will test with the 580 battery and review them for u Dual Coil Cartomizer 1.5ohm Black
          after reading a few reviews l when for one of these to see if l like these different attys l got http://www.vapeescape.co.uk/ego%2F51...-voltage**~241
          • dik
            • Apr 2009
            • 955
            #245
            Smirnoff, ive never used a passthrough so cant say if they provide enough to power the 1.5 ohm dcc's, but for when you're away from a pc you will need a big battery (18650) mod, Here's a link to a cheap one http://www.liberty-flights.co.uk/product.asp?id=160
            I have something similar and with Panasonic 3100 mAh 18650 batteries get 2 days, but its a bit harsh until the battery drops off a bit.
            For relatively cheap vv I recommend a lavatube but it cannot power a 1.5 ohm carto properly as its limited to 2.5 amp drain so it limits the voltage, but use 2.5 ohm dcc's from clouds of vapour in the us or anything else 2.5 ohm or more and these things are bloody awesome, regulated voltage is the bollox, no voltage variation from fully charged to flat battery, dial in anything from 3 to 6 volts and with those Panasonic batteries 2 days of vv vaping
            If you’re a connoisseur of bold flavours & vapour production, then our vape mods section has all you need.
            use ukvapers for 10% off, get the panny's from eBay
            • smirnoff_rules
              • 8603
              #246
              cheers will look into them ..
              also l made my own mix the other week and its mix the same as a pre mixed bottle of menthol l had but my mix dosnt have the same throat hit as there mix , any ideas why that is ? where does the throat hit come from , wot part of the mix needs changing ?
              • dik
                • Apr 2009
                • 955
                #247
                You need more nicotine for more throat hit
                • smirnoff_rules
                  • 8603
                  #248
                  after reading a few reviews l when for one of these to see if l like these different attys l got Ego/510 USB Passthrough **Variable Voltage** £16.99 - Vaping Spares - Batteries & Passthroughs Electronic Cigarettes | Vaping Devices | Accessories | E-Liquid
                  well have to say wot a great little tool this is , works with 580 cart and 510's , these are ok Dual Coil Cartomizer 1.5ohm Black not as good as the 580 atty tho but ok
                  • dik
                    • Apr 2009
                    • 955
                    #249
                    if you get the steel ones or peel off the black label, cut a slit with a hacksaw 10mm from the bottom they work great in these Challenger / Warrior Tank Carts
                    don't buy the special expensive cartos for them as the hole that feeds the liquid is too small and you would need to modify it anyway, used in a tank they last 7 to 10 days of heavyish vaping
                    • leez
                      • Mar 2009
                      • 321
                      #250
                      hi , again might give ago ..one question please ..which flavour tastes the most like tabs ..if possible thanks says something like benson and hedges flavour or something many thanks ..again
                      dreambox 800 tech 500 ( ubuntu 10 .04)... 1 m dish v box 2 acuator ..
                      • dik
                        • Apr 2009
                        • 955
                        #251
                        As the flavours in e liquid are food flavourings none will be exactly like a real cigarette, although as the big tobacco companies are now getting involved that will change, so finding the flavour that suits you is the hard part, have a look here E-Liquid 20ml - E-Cig Liquids as a lot of folks seem to rate their tobacco flavours
                        • mickydibble
                          • 2166
                          #252
                          any good deals on tanks or whatever else thinking about buying something new,still got my riva but only one batt left rather than buyin a new batt and atty etc may as well look for a new one on a good deal any good buys out there at the moment cheers micky
                          • dik
                            • Apr 2009
                            • 955
                            #253
                            The lavatube is the best priced vv mod out there it is a fantastic piece of kit available here for ?46.70 delivered it comes complete with batteries charger and some high voltage attys Electronic Cigarettes - Items - FreedomVape (UK)
                            with the 15 % off code jan15
                            These carto tanks are pretty good too
                            6ML 510 Dual Coil Tank - Single
                            There's a 20% code for there too (NY2012) valid till the end of jan, don't buy the special carto's as normal xxl dcc's work better but you need to cut a slit 10mm from the bottom with a hacksaw or dremel Dual Coil Cartomizer 1.5ohm 10% off with code ukvapers
                            But to get the best from the lavatube I reccomend 2.5 ohm cartos which you need to get from usa 510 XL Dual Coil Cartomizers - Steel 2.5 ohm use discount code big buyer for 10% off, makes them $10.24 for 5 can't remember how much the postage was but not that much and they take maybe a week to come
                            The best tank I've used is a specially made one by clockworks on ukvapers there's a waiting list for them and they cost ?52 and they're loads of hassle to set up but soooo worth it once you get the hang of them
                            And that's my 1000th post hope it was useful!
                            • smirnoff_rules
                              • 8603
                              #254
                              anyone having throat problem ie losing voice and sometime alittle sore ? drink plenty so sure thats ok . went back to a juice l was using before this and still the same ? only use pg base and vg nic so about 60/40 mix
                              • mickydibble
                                • 2166
                                #255
                                Maybe your caning it, could be the juice I have had a couple that do that
