I was suprised how small it is, very fiddley tweeser and reading glasses job to wire it
Help and info on E-Cigarette / e-cigs
interesting read m8 . l have 4 extra cartomisers with this apl-580 will have to see if they burn out fast , still on the first one , so seems ok for a month and now lm only filling a ml at a time now and seem to be using less now , think my problem was trying to smoke like a fag and its not one if u get meLast edited by smirnoff_rules; 30 December, 2011, 20:08.any information provided is for educational/experimental purposes only.Comment
l have samples here , picture below , used a ml out of afew not all , but l only seem to like menthol 18mg , not sure wot ml's are in the bottles it dosnt sayAttached Filesany information provided is for educational/experimental purposes only.Comment
l have been playing around mixing and so on but not concentrated fluid . u got any links where to get them m8 and base fluid tooLast edited by smirnoff_rules; 3 January, 2012, 21:20.any information provided is for educational/experimental purposes only.Comment
the PG + VG can be bought from Boots, only the big stores will have it in stock, but you can order it in,
the nicotine I get from here: Pure54 - Nicotine Base PG or VG - 30ml - ECig Wizard
(Code ECR69 for a 12.5% discount)
and the flavourings, I find the best are from these two suppliers:
Flavourart. La sartoria degli aromi
D.I.Y & Mixing - Perfumers Apprentice Flavouring (code ECR69 for a 15% discount.)
and you may need other bits like bottles and syringes.
if you have an android phone there are plenty of eliquid calculators apps available, I use this one which seems OK:
https://market.android.com/details?i...GVtYW5hZ2VyIl0.Last edited by tshirtman; 3 January, 2012, 22:43.!retupmoc eht ni deppart m'I !pleHComment
meant to say, when you start mixing your own, start by mixing in small quantities, (2mls) and always add less,
you can always add more nicotine or flavour if needed, I also use vodka to thin it out a bit,
and keep a note of the quantities you use, you will soon get to know what your preferred mixes are,
the flavourings are very strong so only add a few drops, in a 2ml mix about 2 or 3 drops.!retupmoc eht ni deppart m'I !pleHComment
wots the best vp or pg for vaping then ?any information provided is for educational/experimental purposes only.Comment
I get my nic from nicvape in the us you won't find cheaper don't get any stronger than 75mg as it's illegal over here and might get nicked by customs, pg is cheapest on eBay(?6 500ml), vg is a cough remedy at boots (89p 200 ml), and they sell menthol crystals for a few pence. To make a menthol concentrate crush the crystals put into empty dropper bottle and add an equal volume of pg ( vg won't work vodka or water might?) warm it under a hot tap until dissolved, then add 1 or 2 drops per ml to your pre mixes to mentholate them or include as a flavour if mixing from scratch, awkward to do links as using crappatalk on phone, best mixing calculator I've found is called "ejuice me up"sigpic
another happy customer
Sent from my keyboard using fingers to typeComment
when u get to a pc post me ebay links m8 , l looked but couldnt work out the best and how to mix nic into itI get my nic from nicvape in the us you won't find cheaper don't get any stronger than 75mg as it's illegal over here and might get nicked by customs, pg is cheapest on eBay(?6 500ml), vg is a cough remedy at boots (89p 200 ml), and they sell menthol crystals for a few pence. To make a menthol concentrate crush the crystals put into empty dropper bottle and add an equal volume of pg ( vg won't work vodka or water might?) warm it under a hot tap until dissolved, then add 1 or 2 drops per ml to your pre mixes to mentholate them or include as a flavour if mixing from scratch, awkward to do links as using crappatalk on phone, best mixing calculator I've found is called "ejuice me up"any information provided is for educational/experimental purposes only.Comment
the reason I thin mine out with a bit of vodka, is I found if I use to much PG my chest became tight, and I started getting a lot of muscle cramp, but it's personal preference,
VG will give you more vapor, and if you are using a tank it's better to have a slightly thicker mix so you've less chance of leaking,
but if you are using a cartomiser I find it's better to have a 50/50 mix, if it's to thick it wont soak into the material filling.!retupmoc eht ni deppart m'I !pleHComment
using a tank and get a small leak now and again so might try vg then , MENTHOL CRYSTALS 50g PREMIUM MENTHOL CRYSTALS - HIGH PURITY | eBaythe reason I thin mine out with a bit of vodka, is I found if I use to much PG my chest became tight, and I started getting a lot of muscle cramp, but it's personal preference,
seen these but cant see pg or vg juice on ebay tho , looked all over ? and then need to find nic for itany information provided is for educational/experimental purposes only.Comment
here's a link for the pg, get your vg and menthol crystals from boots
Here's a link for cheap nic juice http://www.nicvape.com/store/p/170-30-ml-of-75-mg-ml.aspx
Although I buy the larger sizesLast edited by dik; 3 January, 2012, 22:55.sigpic
