How do you get an 80ft mast under a 65ft bridge?
  • aleister crowley
    • Nov 2011
    • 519
    This is how.
    Cant ave been the first time he had done that but impressive nonetheless...................
    • Johnner
      • 7069
      I know nowt about sailing,but am a bit confused.
      The 2x weights(I'm assuming they are) on starboard are there to keep the boat keeled over slightly to one side ?
      When he wants to straighten up,how come he did'nt drop 'em into the water,straighten up,and then pull them up on board ?
        if there sand, then they would get wet and weight more.
        also, could get damaged in water then buggered for next bridge
        might act as a break and make it hang a right.
        would be more concerned about the INCREDABLE amont of stress on the mounting point.
        would be more safter, to have a hydralic mast to fold down.
        or just have a shorter mast.
        • darrenhyland
          • 1124
          the guy must be a retired physics professor......he calculated that manouver to a t.
          Tools owned..... Kess3 Master, Bitbox, TGFlash, VVDI2 Full, VVDI Prog, VVDI MB Tool, VVDI Mini Tool, VVDI Key Tool Max Pro, VCX series for BMW Ford Mazda Jaguar Land rover VAG Toyota Volvo GM, PCM Flash + Scanmatik2, Lonsdor K518ise, Magic tank and every other piece of Chinese crap out there.
            looks like me bollox hanging out
            • RedSpider
              • 2448
              he can do all the maneuvering he wants but i bet he can't dodge a slab dropped from the bridge as easily
              Syntax Error : Integer Out Of Range
              Hooray For Tits & Fannies
