no signal after house move? Help request
  • zfish
    • Jan 2013
    Hi. I've just moved into a house which had a functional TV when we viewed it, but I've now tried setting up two TVs, one with built-in freeview and the other via a freeview box, and neither can find a signal. The house has a couple of aerial sockets (tried both; with different cables) and as the house is only about 6 years old, one would assume the wiring should be ok. The wires coming into the loft also seem intact.
    Does anybody have any ideas? With my 2 yr old repeatedly calling for 'CBBees', this is going to drive me mad!
  • looly
    • Mar 2010
    • 1257
    Chances are that the aerial has moved during high winds. Best to get an aerial guy in to sort it out for you.
    if this post was usefull
    please press
    the thanks button
    • bandit boy
      • 155
      Have you tried a rescan on the tv it may be picking up another region
      • DOUGALMCD
        • May 2011
        • 3229
        Do the wires connect to an aerial?
        • cactikid
          • 12017
          where is the hidden sat dish ,does your socket on the wall say anything on the face plate.
          • johnboy1974
            • 3418
            Pop,up to the attic the arial maybe running through a booster and it may be powered down.
            See if you can find where the coax cable comes into the loft from outside.
            Sent from my iPad using Tapatalk HD
            • Kalipo
              • 1687
              I bet 100 rupees that your not actually plugging it into an ariel socket..
              • jcgrumbles
                • Nov 2010
                • 944
                Just get the ladder out and run up some new cable yourself,either that or your going to have to dress up as mr tumbles for the next few years..
