Gardeners, I need advice please.
  • Saltire
    • 1361
    I was wondering if theres such a thing as a weedkiller that will kill weeds in a plant/tree bed but leave the plant/tree healthy, is there ? or is it just a case of the old style weeding and using the hoe etc that can do the job ??
    Reason why i ask is i have a tree bed of 30 odd young trees and the weeds are a pain in the arse in the bed.
  • chroma
    • 1976
    Yes.... and No.
    Depends is actualy more accurate, depends on the spieces of tree and weeds involved.
    Much in the same way a doctor would issue a broad spectrum antibiiotic (which kills the lot) or if he knows which bacterial infection hes combating he'll issue a narrow spectrum to kill that off and leave the rest of your healthy bacteria alone.
    Im not an expert on either to be honest, id suggest going into a local gardening center (not one of the big commercial ones though cause theyre more likely to employ idiot drones who wouldnt have a clue) a local nursery with an actual gardener would be ideal.
    He who laughs last thinks slowest.
    • xant14
      • 2062
      well there are weedkillers that are reasonably safe to the soil, but sprayed on to an actively growing broad leafed weed, attack the weed from the leaf side. Just be slightly more accurate with your spraying, and spray on a sunny day when the weed is stretching its arms in the sun. If the tree is a reaSonable size and healthy. the weedkiller aint gonna do much if any damage. Unless your using Napalm or something. Brings me back to my Nam days...
      • manxspud
        • 1768
        Don’t use products containing Triox... This will soak into the soil and kill any thing it comes into contact with... Roundup is a good one as @Xant14 says you spray it on and it works its way down the leaves and to the roots.... or with rubber gloves on you could pour some into a plastic cup and paint it on with a small brush... best method if weeds and plants are close together.
        PS.... Do you use any type of mulch? ie.. gravel or chipped slate mixed with ground cover plants is a more permanent solution, or chipped bark / coco shell is effective and rots into the ground as a added food source for the plants. I use the chipped slate mixed lots of low growing ground cover plants, adds more interest to the garden. Both methods are effective but you will always have to do a little weeding.
        Best of luck....
        • cactikid
          • 12017
          is the weed wand still around,a sponge on the bottom of the wand with weed killer on it you dab onto weeds so no drift and only kills what you touch.
          • Saltire
            • 1361
            wow, thanks guys, but youz have lost me a bit, hhheehehhe, all i know is my trees are young leylandii and are about 1 meter high at most, so in other words they are young skinny things, , i only planted them about 2 months ago and they were only about knee high then, as for the weeds i have no clue what they are, hope this helps a bit, .
              Not meaning to hijack the thread , BUT can anyone recommend something to kill off tree roots. Cut a shitload of trees down when i moved here Seven years ago. meant to kill the roots off but never got round to it.
              Think they may be Beech trees but not sure. They are cut down to near ground level. So any advice would be welcome.
              • manxspud
                • 1768
                Hi @ Bulldog Some good products here....
                Plant Me Now Weedkillers
                Not sure how long they will take to work... I had 1 in the front garden when moved in this house.... Dug a big hole around... hired astill saw and with a bit of help from a sharpened hand axe dug the sod out. Took about 4hrs...
                and a few B***tards, C**ts ect, but it worked. I rcall somebody telling me to drill a hole as big and deep as poss from the top, and pour in some drain cleaner, But i was in a hurry to get rid off it.
                @Thompson... 30 ~~~~ing leylandii... They grow around 3ft a year... Ok when they are young... Nightmare after they reach 6ft or so... This link should help you out HeHe
                Chain Saws available at Toolbox
                • Saltire
                  • 1361
                  , the idea is to keep them at 6 or 7ft mate, well thats the idea, if that fails then mr chainsaw will be the answer,
                  • dik
                    • Apr 2009
                    • 955
                    Hammer copper nails into the stump that will kill em
                    sigpic another happy customer
                    Sent from my keyboard using fingers to type
                    • Saltire
                      • 1361
                      so back on topic now, weed killer ??
                      • cactikid
                        • 12017
                        dont think it does ,maple tree next door has mildew now all white drilled 6 x 6inch holes in bark hammered 6 x 1/2 ich copper pipes into holes 8 yrs ago bloody thing still growing .
                        • Evastar
                          • Apr 2009
                          • 1220
                          Thomson, you don't need weed killer. Leylandi have a type of poison in their needles and after a while you will notice that nothing at all will grow under them.
                          I have to say i am not a fan of leylandii, and if you have children with asthma/breathing problems i would advise you to get rid of the trees now, as they have been linked to breathing problems and bringing on asthma attacks.
                          • forntida
                            • 1281
                            Did you get maple resin on tap?
                            I can't wake up Grumpy now in case I am accused of Dwarfism
                            • cactikid
                              • 12017
                              sorry only maple syrup for my pancakes in the morning
