Outlook, help needed
  • ste6106
    • Mar 2009
    • 444
    Help needed good people, whe i try to open my work outlook i get an error message saying there are errors in a file etc etc run the scan.pst tool (inbox repair tool) I have run the scan.pst and when this is scanning it also gets an error
    anyone ideas how to fix the file?
    Life is a party and parties arent meant to last.
  • forntida
    • 1281
    What is the exact message?
    You should find the help you need here;
    Outlook Forum - Problem? You will find the answer here!
    good luck.
    I can't wake up Grumpy now in case I am accused of Dwarfism
    • ste6106
      • Mar 2009
      • 444
      Cannot start Microsoft Office Outlook. Cannot Open the outlook windoe. the set of folders cannot be opened. The file C;\Users\name\appdata\local\microsoft\outlook\outl ook.pst is in use and cannot be accessed. Close any application that is using this file and then
      • forntida
        • 1281
        I dont use Outllook myself but I am sure a member will be along shortly to assist you.
        • Mr Pumpy
          • 1467
          Ive got a big hammer in me garage if thats any use Ste.
          I refuse to answer that question on the grounds that I do not know the answer.
          • ste6106
            • Mar 2009
            • 444
            Cheers Pumpy, yeh feel like using a big hammer i were supposed to finish work 4 hours ago but still here!!
            • Dreamer
              • 2020
              if you have the windows disk you could try the repair option perhaps
              The Falkirk Wheel.sigpic The only rotating boat lift of its kind in the world
              • ste6106
                • Mar 2009
                • 444
                Will do Monday Dreamer had enough for today theres beer to br drank and emails not be worried about for 48 hours!!!
                • forntida
                  • 1281
                  So the outlook is good now.
                  • ste6106
                    • Mar 2009
                    • 444
                    Its certainly better
                    • storky1987
                      • May 2024
                      How did we go with this issue?
                      • Genas
                        • May 2024
                        • 4
                        It sounds like you’re experiencing issues with your Outlook data file. Since you’ve already run the scanpst tool and it encountered errors during the scan, it’s possible that the file is corrupted beyond repair using the built-in tool. You might want to try using third-party PST repair tools that are specifically designed to handle more severe file corruption issues. These tools can sometimes recover more data from damaged PST files. Additionally, make sure to back up your Outlook data regularly to avoid data loss in case of file corruption.
