Android Developers
  • SouthernComfort
    • Feb 2011
    • 403
    Android Developers
    What is Android?
    Android is a software stack for mobile devices that includes an operating system, middleware and key applications. The Android SDK provides the tools and APIs necessary to begin developing applications on the Android platform using the Java programming language.
    Android SDK
    Android SDK | Android Developers
    Here's an overview of the steps you must follow to set up the Android SDK:
    Prepare your development computer and ensure it meets the system requirements.
    Install the SDK starter package from the table above. (If you're on Windows, download the installer for help with the initial setup.)
    Install the ADT Plugin for Eclipse (if you'll be developing in Eclipse).
    Add Android platforms and other components to your SDK.
    Explore the contents of the Android SDK (optional).
    Installing the SDK:
    Installing the SDK | Android Developers
    Developer's Guide:
    The Developer's Guide | Android Developers
    Package Index:
    Package Index | Android Developers
    Developer Resources:
    Developer Resources | Android Developers
    OEM USB Drivers
    OEM USB Drivers | Android Developers
    Developing
    Introduction | Android Developers
    Tools
    Tools | Android Developers
    Open Source Project:
    Welcome to Android | Android Open Source
    Initializing a Build Environment
    Initializing a Build Environment | Android Open Source
    Downloading the Source
    Downloading the Source Tree | Android Open Source
    Building and Running
    Building the System | Android Open Source
    System Requirements
    The sections below describe the system and software requirements for developing Android applications using the Android SDK.
    Supported Operating Systems
    Windows XP (32-bit), Vista (32- or 64-bit), or Windows 7 (32- or 64-bit)
    Mac OS X 10.5.8 or later (x86 only)
    Linux (tested on Ubuntu Linux, Lucid Lynx)
    GNU C Library (glibc) 2.7 or later is required.
    On Ubuntu Linux, version 8.04 or later is required.
    64-bit distributions must be capable of running 32-bit applications.
    Supported Development Environments
    Eclipse IDE
    Eclipse 3.5 (Galileo) or greater
    Note: Eclipse 3.4 (Ganymede) is no longer supported with the latest version of ADT.
    Eclipse JDT plugin (included in most Eclipse IDE packages)
    If you need to install or update Eclipse, you can download it from Eclipse Downloads.
    Several types of Eclipse packages are available for each platform. For developing Android applications, we recommend that you install one of these packages:
    Eclipse IDE for Java Developers
    Eclipse Classic (versions 3.5.1 and higher)
    Eclipse IDE for Java EE Developers
    JDK 5 or JDK 6 (JRE alone is not sufficient)
    Android Development Tools plugin (recommended)
    Not compatible with Gnu Compiler for Java (gcj)
    Hardware requirements
    The Android SDK requires disk storage for all of the components that you choose to install. The table below provides a rough idea of the disk-space requirements to expect, based on the components that you plan to use.
    Component type
    Approximate size
    Comments
    SDK Tools
    35 MB
    Required.
    SDK Platform-tools
    6MB
    Required.
    Android platform (each)
    150MB
    At least one platform is required.
    SDK Add-on (each)
    100MB
    Optional.
    USB Driver for Windows
    10MB
    Optional. For windows only.
    Samples (per platform)
    10MB
    Optional.
    Offline documentation
    250MB
    Optional.
    Note that the disk-space requirements above are in addition to those of the Eclipse IDE, JDK, or other prerequisite tools that you may need to install on your development computer.
    "What we've got here is failure to communicate."
  • RSwire
    • 1247
    Question about this, I'm new to the Android stuff, and wondering what SDK can do for me, what is it for exactly. This fone does more stuff than I will ever need, it is awsome, I've had it for a couple months and it still amamzes me. I like to learn as much as I can.
    A DAY YOU DIDN'T LEARN SOMTHING NEW IS A WASTED DAY.
    Please don't pm me for keys, that is what the forum is for.
    If it helped, please use the thanks button, if thanks isn't enough use the scales.
    • SouthernComfort
      • Feb 2011
      • 403
      Android Application Development.
      New to it all myself, Android is still in it's infancy compared to it's competitors, due to the open source nature of the project users are encouraged to develop their own applications. These are the tools.
      • Canker_Canison
        • May 2010
        • 3905
        Just to use a different kind of english to SC's post..
        The Android SDK (Software Development Kit) is a set of tools & programs that you can use to develop/create your own apps.
        These are used on a PC & have nothing to do with the phone, other than the end result will be used on an Android phone.
        It's a little like the software available for creating websites instead of learning to program in HTML.
        If you're old enough to remember the Amiga, this is also like AMOS... Although I'm probably making things sound to easy.
        Canker
        [COLOR=Green]
        • SouthernComfort
          • Feb 2011
          • 403
          Small oversight on my part, trying to fit all the information required in a concise manner. You can run most development in a virtualisation environment, the SDK basically allows you to build your own applications and games. The open source project lets users participate in the development of the end source, ie if you want to make something better do it yourself.
