Whats the best programming language to start with if i plan on going into android dev
  • pflame
    • Jun 2012
    • 33
    Whats the best programming language to start with if i plan on going into android development.
  • happy_highlander
    • 3535
    Android is java based if I'm not mistaken, but I might be wrong
    • pflame
      • Jun 2012
      • 33
      Read that too,guess i got to get my engines started for the task.
      • Bann32
        • Oct 2011
        • 518
        Yes its mainly java based, are you a programmer in other languages?
        If so which? I may be able to point you in right direction, if i know what previous programming experience you have if any.
        • pflame
          • Jun 2012
          • 33
          Am a newbie to programming yet to start anything meaningful.
          • Yanti
            • Jun 2012
            I would have a read of this to get you started on understanding even a little about Java and then you are going to need tools for the job.
            Grab this and the Eclipse IDE from here.
            Take a look at this site to help get you started.
            I would suggest maybe looking at some fundamental concepts to programming that are similar from language to language as I believe Java can be a little full on to just walk into.
            But keep at it! My housemate is a pretty good Java developer so if you have any questions send them my way and I will ask him for you.
            • yj09
              • Jun 2012
              is it possible to develope application using other languGE
              • tsuncello
                • Jul 2012
                Definately Java.
                • pickledfrog
                  • Feb 2012
                  • 57
                  best to learn how to design a data flow and then to write an algorithm, then that can be translated in to Java or any other language for cross platform use.
                  • trcomp911
                    • Jul 2012
                    You will need to know at least some Java but you can also write your code in C and call into it via the JNI if you prefer.
                    • Aadamgibson
                      • Aug 2012
                      • 6
                      Here's a list of languages that can be used to develop on android:
                      Java - primary android development language
                      C++ - NDK for libraries, not apps
                      Python, bash, et. al. - Via the Scripting Environment
