How To Create an iPhone Theme?
  • biffo1
    • 420
    For those of you who are eager to find a way to customize your iPhone, i have great news! Not only is it possible but relatively simple.
    First thing first. Your iPhone needs to be jailbroken. After your iPhone is jailbroken, you need to install OpenSSH. To do this, open Cydia on your newly jailbroken iPhone and click on search option on the right bottom corner. Type OpenSSH and install it. It will allow you to connect to your iphone wirelessly using your terminal and/or CyberDuck (Mac users). This is essential step since it will allow you to explore your iPhone in a similar way you explore your Mac. It will give you access to your /root directory where all of the applications and documents reside.
    Next...
    Download and install WinterBoard from Cydia.
    Next...
    Download and install CyberDuck on your Mac. After successful installation, configure it to connect to your iPhone. Follow this tutorial if you need to.
    About the creation of a theme?
    To customize your iPhone you need to create your own dock, icons, mini dock, status bar and wallpaper. Here are the dimensions for each one of them:
    Dock - 320x91
    Icons - 59x60
    Mini Dock - 320x37
    Status Bar - 320x20
    Wallpaper - 320x480
    You can also download an ?example? theme i made specially for you to see how everything should look like. You can find it here. (Note: You will have to unzip the file before applying it as a theme.)
    For the sake of this tutorial lets use my ?example? theme.
    To apply it, follow these steps:
    1. Connect your laptop/computer and iPhone to your wireless network
    2. Open CyberDuck[mac or winscp windows] and connect it to your iPhone
    3. Navigate your CyberDuck or winscp windows to /Library/Themes and copy ?example? theme to Themes folder (this is the place where all you themes will reside).
    4. On your iPhone or iPod Touch open WinterBoard and select the theme to be applied. Wait for your gadget to respring and you are good to go!
    [CENTERsigpic[/CENTER]
