ne one got the new driver to work from dvd yet ? done the ciso249 and 250 still no luck just hangs on open of game intro all on n e help pls
DRIVER
Which new driver?
Are you trying to run burnt DVDs or HDD games?
The DVDs will depend on your Wii version to older ones should run burnt games but the newer ones don't.Keith
2010 Golf GTD (170) -
Word is dvd are working on neogamma 9 but I wouldn't know for sure I only use hdd nowadays
It is looking like this game loads with d2x cios pack...Now I have found the cios pack of wads but it looks like you need to follow the full tutorial and reinstall all your wad bases for d2xv6 base[57] on ios 250 to work and i'm not to sure about this without further investigationComment
Ok so its Driver San Francisco your having trouble running of a burnt DVD?
I'm downloading the Wii and PC versions now I will let you know if it works of an HDD?Keith
2010 Golf GTD (170)Comment
Here you go for anyone wanting to play Driver san francisco and can't get it to run Digital Kaos - Downloads - Driver San Francisco Fix. this will patch ios 249 and install usbloader gx. Should also work for you costa loading from disk through this loader with the mount dvd drive option on the top right of the screen and make sure 249 is selected in settings. If you already have usb loader gx installed try loading on 249 before patching iosLast edited by happy_highlander; 6 September, 2011, 22:38.Comment
Ok I put Driver San Francisco on the HDD and ran it through WiiFlow. It starts up and you can set all the option but when you run the first option on the menus the screen shows the controller function/switches and it says Loading and the icon rotates then it stops and does nothing you have to power it down.
I tried it again through CFG Loader and chose another option to try the time trial and that worked. I tried it again wiith USB Loader GX and it locked up again when it said Loading.
Whether there is a glitch with this game I'm not sure? I've Googled for this for this problem and quite a few say it locks up?Keith
I have it running on usb loader gx on 249 with no lockup but it does freeze on uloader. I am using usbloader gx full channel r938 and my cios 249 has been previously patched with cod black ops patch both are in the downloads section. The file I uploaded as driver fix has been confirmed as working. And the glitch you talk about is the know AP in story mode which is why a lot of folk are having trouble.Ok I put Driver San Francisco on the HDD and ran it through WiiFlow. It starts up and you can set all the option but when you run the first option on the menus the screen shows the controller function/switches and it says Loading and the icon rotates then it stops and does nothing you have to power it down.
Using the above settings this game will load and save but freeze after missions for full function with no freezing use the driver san francisco fix pack in post 9Comment
