Skylanders Swap Force Portal not working
  • bowie
    • 475
    #16
    i think its the game itself as others are having similar problems. try disconnecting your wii from the internet or, at the point where the game freezes try playing with one non swap force skylander. this could be a problem activision needs to sort out.
    you could also try unfolding the usb cable completely and placing the portal away from the wii. or lastly try freeing up about 1500 blocks on the wii
    Men of Harlech onto glory
    This shall ever be your story
    Keep these fighting words before ye
    Cambria will not yield
    • TechLife
      • Dec 2013
      #17
      I'll keep it in mind, thank you. I switched from 223 to 247 and it seems to be working great so far. Time will tell...
      • ftual
        • Jan 2014
        Thanks Keithuk: you procedure worked a treat !
        • Keithuk
          • 2264
          #19
          Welcome to DK ftual.
          I prefer you click the Thanks button as that is logged.
          Keith
          2010 Golf GTD (170)
          • rshemtov
            • Feb 2014
            #20
            Skylander swap portal doesn't work
            Hi folks,
            I have a similar problem where the Skylanders swap force portal is not recognized .
            I followed Kethuk instructions but the portal still shown as disconneced.
            Please help !!!
            following is my syscheck:
            sysCheck v2.1.0b19 by Double_A and R2-D2199, Nano
            ...runs on IOS58 (rev 6176).
            Region: PAL
            System Menu 4.3E (v514)
            Drive date: 2007.02.13
            Homebrew Channel 1.1.0 running on IOS58
            HomebrewFilter ist nicht installiert
            Hollywood v0x11
            Console ID: 77522611
            Boot2 v3
            Found 155 titles.
            Found 52 IOS on this console. 2 of them are stub.
            IOS4 (rev 65280): Stub
            IOS9 (rev 1034): No Patches
            IOS10 (rev 768): Stub
            IOS11 (rev 16174): Trucha Bug, NAND Access
            IOS12 (rev 526): No Patches
            IOS13 (rev 1032): No Patches
            IOS14 (rev 1032): No Patches
            IOS15 (rev 1032): No Patches
            IOS17 (rev 1032): No Patches
            IOS20 (rev 16174): Trucha Bug, NAND Access
            IOS21 (rev 1039): No Patches
            IOS22 (rev 1294): No Patches
            IOS28 (rev 1807): No Patches
            IOS30 (rev 16174): Trucha Bug, NAND Access
            IOS31 (rev 3608): No Patches
            IOS33 (rev 3608): No Patches
            IOS34 (rev 3608): No Patches
            IOS35 (rev 3608): No Patches
            IOS36 (rev 3608): No Patches
            IOS37 (rev 5663): No Patches
            IOS38 (rev 4124): No Patches
            IOS40 (rev 16174): Trucha Bug, NAND Access
            IOS41 (rev 3607): No Patches
            IOS43 (rev 3607): No Patches
            IOS45 (rev 3607): No Patches
            IOS46 (rev 3607): No Patches
            IOS48 (rev 4124): No Patches
            IOS50 (rev 16174): Trucha Bug, NAND Access
            IOS52 (rev 16174): Trucha Bug, NAND Access
            IOS53 (rev 5663): No Patches
            IOS55 (rev 5663): No Patches
            IOS56 (rev 5662): No Patches
            IOS57 (rev 5919): No Patches
            IOS58 (rev 6176): USB 2.0
            IOS60 (rev 16174): Trucha Bug, NAND Access
            IOS61 (rev 5662): No Patches
            IOS62 (rev 6430): No Patches
            IOS70 (rev 16174): Trucha Bug, NAND Access
            IOS80 (rev 16174): Trucha Bug, NAND Access
            IOS202[60] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
            IOS222[38] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
            IOS223[38+37] (rev 4, Info: hermes-v4): Trucha Bug, ES Identify, NAND Access, USB 2.0
            IOS224[57] (rev 65535, Info: hermesrodries-v6): Trucha Bug, NAND Access, USB 2.0
            IOS236[36] (rev 65535, Info: rev 3351): Trucha Bug, ES Identify, NAND Access
            IOS245[37] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
            IOS246[38] (rev 21008, Info: d2x-v8final): Trucha Bug, ES Identify, NAND Access
            IOS247[53] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
            IOS248[55] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
            IOS249[56] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
            IOS250[57] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
            IOS251[58] (rev 21008, Info: d2x-v8final): Trucha Bug, NAND Access, USB 2.0
            IOS254 (rev 65281): BootMii
            BC v5
            MIOS v10
            Report generated on 2014/02/28.
            • Keithuk
              • 2264
              #21
              Welcome to DK rshemtov.
              I don't see anything wrong with that sysCheck only PriiLoader 0.7 is missing, add it to the SD card and run it from Homebrew and set it to block online and disc updates, you can turn off the 'A' safety prompt on startup I do.
              Keith
              2010 Golf GTD (170)
              • rshemtov
                • Feb 2014
                #22
                Priiloader 0.7 installed. problem still exists. Syscheck log:
                Region: PAL
                Priiloader installed
                Hollywood v0x11
                Boot2 v3
                Found 157 titles.
                BC v5
                MIOS v10
                Report generated on 2014/03/02.
                Thanks for your support
                • Keithuk
                  • 2264
                  #23
                  As I said:
                  This game uses a USB portal which you get when you buy the game.
                  Keith
                  2010 Golf GTD (170)
                  • ap3260
                    • Apr 2014
                    Hi having similar problems here also
                    Have tried to follow the above mentioned steps but the portal is still still coming up as not detected.
                    Using USBLoader GX and have the actual portal.
                    Syscheck is as follows:
                    sysCheck v2.1.0b19 by Double_A and R2-D2199 Nano
                    Region: PAL
                    System Menu 4.2E (v482)
                    Drive date: 2008.07.14
                    Homebrew Channel 1.1.0 running on IOS61
                    Hollywood v0x21
                    Console ID: 128496313
                    Boot2 v4
                    Found 114 titles.
                    Found 55 IOS on this console. 5 of them are stub.
                    IOS3 (rev 65280): Stub
                    IOS11 (rev 16174): Trucha Bug NAND Access
                    IOS16 (rev 512): Stub
                    IOS20 (rev 16174): Trucha Bug NAND Access
                    IOS30 (rev 16174): Trucha Bug NAND Access
                    IOS40 (rev 16174): Trucha Bug NAND Access
                    IOS50 (rev 16174): Trucha Bug NAND Access
                    IOS51 (rev 4864): Stub
                    IOS52 (rev 16174): Trucha Bug NAND Access
                    IOS60 (rev 16174): Trucha Bug NAND Access
                    IOS70 (rev 16174): Trucha Bug NAND Access
                    IOS80 (rev 16174): Trucha Bug NAND Access
                    IOS202[60] (rev 65535 Info: hermesrodries-v6): Trucha Bug NAND Access USB 2.0
                    IOS222[38] (rev 4 Info: hermes-v4.0): Trucha Bug ES Identify NAND Access
                    IOS223[38] (rev 4 Info: hermes-v4.0): Trucha Bug ES Identify NAND Access
                    IOS224[57] (rev 65535 Info: hermesrodries-v6): Trucha Bug NAND Access USB 2.0
                    IOS236[36] (rev 65535 Info: rev 3351): Trucha Bug ES Identify NAND Access
                    IOS245[37] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
                    IOS246[38] (rev 21008 Info: d2x-v8final): Trucha Bug ES Identify NAND Access
                    IOS247[53] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
                    IOS248[55] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
                    IOS249[56] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
                    IOS250[57] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
                    IOS251[58] (rev 21008 Info: d2x-v8final): Trucha Bug NAND Access USB 2.0
                    BC v6
                    MIOS v10
                    Report generated on 2014/06/22.
                    Any ideas on where i'm going wrong would be great!
                    • clydep
                      • Jan 2015
                      #25
                      He Keithuk,
                      I followed this guide exactly, or at least I thought I did. Here is my sysCheck, do you see anything out of sorts? I'm still getting the error that the portal is disconnected.
                      Region: NTSC-U
                      System Menu 4.3U (v513)
                      Drive date: 2006.05.26
                      Homebrew Channel 1.1.2 running on IOS58
                      Hollywood v0x11
                      Console ID: 34783004
                      Boot2 v4
                      Found 121 titles.
                      Found 55 IOS on this console. 4 of them are stub.
                      IOS16 (rev 54321): Trucha Bug, ES Identify, Flash Access, NAND Access
                      IOS36 (rev 65535): Trucha Bug, ES Identify, NAND Access
                      IOS90 (rev 54321): Trucha Bug
                      IOS222[38] (rev 4, Info: hermes-v4.0): Trucha Bug, ES Identify, NAND Access, USB 2.0
                      IOS236 (rev 65535): Trucha Bug, ES Identify, NAND Access
                      IOS254 (rev 65280): Stub
                      BC v6
                      MIOS v10
                      Report generated on 2015/01/06.
                      • Throwaway8430
                        • Feb 2021
                        As you may have read on here thats a typical sysCheck of a Wii thats only been softmodded as you have originally showed 16 IOS's that are Stub. You do have IOS36 and IOS236 that's all but you need to reduce that 16 down to 4 or 5.
                        Download ModMii6.3.0 and run it from Windows. Use the SU option from the main menu and find the location of the sysCheck.csv from the sysCheck which is on the root of the SD card. That will download all missing wads and apps to COPY_TO_SD sub folder just add all files and folders to the SD card.
                        ModMii only installed 2 d2x v8.0 wads download d2x v8 Final wad pack and install all 7 wads when you install the other wads.
                        Put the SD card back in the Wii and run Homebrew. You already have IOS236 but it won't hurt to install it again. Run IOS236 Installer v5 Mod first before you install any other wads. Install all wads with Multi Mod Manager (MMM) should be the first app listed select it and load it.
                        Watch for the Installed OK message after each one. If any don't say that message make a note of the wad name and back out. Scroll down to the wad that didn't install and press the + button the put a green + next to it then press 'A' to see that wads name listed then press 'A' to install again.
                        If you have to update to 4.3 then the Shopping Channel may work. If it doesn't without doing another system update don't bother just install my RVL-Shopping-21
                        Do another sysCheck to make sure everything installed correctly and post that.
                        Cool, this advice still works in 2021. Some pointers for other latecomers. Follow Keithuks advice closely, it's easy to overlook crucial steps. For me, I thought Modmii would copy the relevant files to the SD card, but you have to do it manually. The links don't work anymore and MMM and the IOS236 Installer are not included.
                        d2x v8 Final wad pack: http://www.mediafire.com/file/x4mf58...final.rar/file
                        Multi Mod Manager: https://gbatemp.net/download/multi-m....13015/history
                        ModMii: above link still good.
                        IOS236 Installer: https://sites.google.com/site/comple...attredirects=0
                        I finally got Skylanders Swap Force working, on 4.3E, after installing the Final Wad pack. I run the game with USB Loader GX on cIOS 247 or 248. With cIOS 222 or 223 the portal lights up but the screen stays black.
                        Good luck!
