Fix 1:If you have an old original xbox1 get the rubber feet off it
cut 2 of them in half.....leaving 4 bits of rubber with curved ends.
Dissasemble 360 completely and take motherboard out of case.
Stick the 4 Bits of old xbox rubber onto ram chips with double sided sticky pad.
They may already have squishy pink pads on remove these first.
Next take the other 2 whole xbox rubber feet and cut the curved ends off.
Remove xclamps from motherboard and take the hard black plastic centres out.
Place the rubber squares on the motherboard and make sure they fit nicely
in free square space on processors, not on top of any resistors etc, and fit the xclamps back on top.
Re-assemble 360, but do not put lid on.
Turn on without connecting motherboard fan.
Wait till 3 red lights become 2 red lights and then wait 1 more minute.
Turn off 360 from mains supply as it will not turn off from front button.
Re-connect motherboard fan.
Wait 10-15 mins to cool.
Turn on 360 should now work flawlessly although fan will be louder than
it was previously and will remain so.
Fully reassemble 360.
This fix has worked for me for 4 red light (flashed) xbox360's
and has continued to work for past 5 months.... and is still working now.
If you have not flashed / opened your xbox previously then send it to
Microsoft and do not even attempt this fix.
Regards
Niteman1969
__________________________________________________ _______________________________
Fix2:3 RED LIGHT FIX
The problem with the towel trick is that it heats up parts of the 360 that you dont want heating up and can cause the tiny capacitors to fall off the bottom of the mother board. they are about 1mm in size you you can forget finding them or re-soldering them back on if this happens.
They is a way to manually fix the 360 but it does involes a little skill and you must be really careful when doing this.
I have repaired loads of 360's with this method.
You have to fully take out the mother board.
Flip it over and remove the X-clamps on the back of the heatsinks covering the cpu and gpu.
Remove all the thermal paste from the cpu and gpu also remove it all from the heatsinks.
Ive found the best way to get this off is to spray some WD-40 into a cup and dip cottom buds into it (the one's that people clean there ears with)
rub the cotton buds onto the old thermal paste to get it off.
You will have to make sure that they all are very shiny clean (mirror like)
Put new thermal paste onto the gpu and cpu (small amount) and spread it evenly.
Now put the heatsinks back on the motherboard.
NOTE: it is best to throw the xclamps and the clamp bolt going into the heat sinks and relace with M5 10mm machine screws and washers but that will be a major big post to tell all that so i'll just stick to the basics.
When the heatsinks are back on Leave the motherboard out ogf the case for now.
put the front display onto the motherboard, plug in the tv cable and power cable to the mother board (DONT put the dvd drive and fans back yet)
power on the 360,
If the 3 red lights are gone put the full console back together.
If the 3 red lights are still there leave the console on a good heat resistant surface. eg NOT on the carpet or plastic. Use a chopping board or kitchen side for it.
Have the 360 powered on until the 3 red lights turn into 2 red lights
NOTE: this will only heat the GPU and CPU not the full board.
When its changed to 2 red lights leave for 1-2 mins then turn power off at the plug socket outlet.
Leave to stand for 15-20 mins to cool down then turn back on.
The 3 red lights should now have gone back to the wonderful green lights.
Put the console back together (dont forget to connect the dvd drive cables back up)
Your console should now be fixed.
Like i said previous, for the best fix swap the x-clamps for M5 10mm bolts and washers. It stops the board from warping when it gets hot and clamps the GPU and CPU down nice and snug.
The most common reason for the 3 red lights is the board warps due to center pressure of the x-clamp under heat and pops the corner of the GPU/CPU off the board (hairline), only very slightly but it does.
Hope this helps some of you 360 owners out.
chongsparks
__________________________________________________ _________________________________
Alternatively, if your warranty is still valid then send it back, they should fix their own problems. if your warranty is void then you may aswell try these.
hope this helps.
Regards
Niteman1969
power on the 360,
chongsparks
hope this helps.
