Ethernet Splitter
  • ssttaagg
    • Feb 2010
    • 71
    Ethernet Splitter
    Hi all.
    I have a ethernet cable from my router to the back of my computer and would like to know if i got a 2 way splitter with one still going to the computer could i run another cable from the splitter and put a wifi booster on the end of it in my work shop.
    dave.
  • dasteph
    • 1293
    Originally posted by ssttaagg
    Hi all.
    dave.
    i have tried using a splitter for two pcs which did not work, you would be better with an ethernet hub.
    something similar to these......https://www.amazon.co.uk/s/ref=nb_sb...=2H20IEQI022JH
    • agustinazo
      • May 2018
      • 13
      Estoy en una situación similar, me valdría esta solución: https://www.cablematic.es/ref/RC21?g...iABEgKH8fD_BwE
      Un saludo.
      • nexusjose
        • Dec 2013
        • 175
        Un saludo.
        Use a switch ethernet is better
        Enviado desde mi iPhone utilizando Tapatalk
        • Jessb
          • Oct 2021
          Never use a splitter. Just get yourself a unmanaged switch. Doesn’t need to be anything special for what your needing it to do.
          • vlassaco
            • Mar 2025
            A switch will cost just 20€
            you can also opt for an acces point with ethernet ports embedded.
            So the main wire that is now attached to your pc runs to the Acces point. from the acces point it goes to your pc.
            I would always reccomend using an Acces point over a 'wifi repeater'.
            They can work over poe even where you don't have 230v running.
