First, Dell owners by aware that free generators do NOT work for the following: Service tags ending with -3A5B, -1D3B, -1F5A, PPID #s and System disabled codes that are larger than 5 digits
Dell by service tag
When a rude screen pops up saying it is protected by a password for Service Tag # (example: 1A2BC34-595B), This is a bios password. Will be 7 char with 4 char suffix. Enter that into generator using all capital letters. Click Generate and use password listed under “Dell by serial number”. Can do the same with hard drive passwords (example: ***12AB34C5-595B) Notice it has 11 char with 4 char suffix. If it displays stars then use them. If it has a suffix of -1D3B or -1F5A, then you’re out of luck. They are to new and the free generates will not work yet.
Important Input instructions: Passwords are for QWERTY keyboard only (standard US). Case sensitive. Some units only require pressing <enter> after password, some require pressing <ctrl>+<enter> after password and some require holding down <ctrl> while pressing <enter> once or twice.
Dell, Acer and some others with generic Phoenix bios
If you get a plain screen that just says Enter Password then enter 3 wrong passwords and a System Disabled code will pop up(example: 12345). Don’t worry, just shut down computer, restart and the disabled thing goes away. Now enter that number into generator, click Generate. Write down the top password generated. Click Generate several times (maybe 5,6 or more times) and write down password after each time. Try each password on your machine until you hit one that works by entering password and pressing <enter>. The same can be done for hard drive password, be aware that it does not always work for hard drives.
i do not know if i am allowed to upload but here it is , a small keygen for dell BIOS and HARD DISK password , i do not know on what models it will work but give it a try i know on a DELL Latitude D630 it do work
and a simple thanx is all i ask if it works NO PASS !! free for all
DELL(Bios Master Key Generator).rar
Dell by service tag
