Clone HDD to SSD
  • BraLaas
    • Jun 2017
    • 373
    Clone HDD to SSD
    Good day masters..
    Could anyone one please help me to clone the data from on hdd to another
    Old hdd...500 gb
    New hdd...240 gb
    Please guys
    Thank you
    Sent from my HUAWEI CAN-L01 using Tapatalk
  • AirShowNut
    • 329
    If there is enough room on the new drive to take all the data from your old one then give Acronis true image a try, i have heard good things about it and i will be using it to migrate my data to a new SSD when it arrives.
    • accodinguk
      • Oct 2019
      • 242
      Originally posted by BraLaas
      Good day masters..
      Old hdd...500 gb
      New hdd...240 gb
      Please guys
      Thank you
      On ebay buy a HDD clone tool offline. This will do a full clone inc system.
      https://www.ebay.co.uk/itm/HDD-Docki...0AAOSwfttdmho2
      Most easiest way ever
      If I helped, please consider hitting the Thanks & Rep buttons
      • chentron
        • Nov 2019
        • 11
        clonezilla can meet your requirements. you can boot clonezilla with usb drive.
        it is free tool.
        • arky4
          • Mar 2009
          • 224
          i believe the hdd has to have to the same capacity, or more as the one your coping.
          tiger4
          • DJSteve
            • Sep 2012
            id say acronis aswell, have used it before and its brilliant, but as mentioned ssd must be big enough to hold all the data off the old drive
            • toyota123
              • Sep 2019
              • 440
              use clonezilla ... so easy
              DON'T FORGET TO USE BUTTONS BELOW REP & THANKS
              • adamski1952
                • Jul 2021
                • 6
                Take a look here. https://www.easeus.com/disk-copy/clo...g-software.htm
                • NKTA
                  • Jul 2021
                  I used AOMEI Backupper Professional wich is also relatively easy... Recommended.
                  • unBond
                    • Sep 2019
                    • 4
                    clonezilla is old, but works great and is free.
                    • phil242
                      • 10
                      Good day masters..
                      Old hdd...500 gb
                      New hdd...240 gb
                      Please guys
                      Thank you
                      Hi,
                      The best software you can find for this job is Macrium.
                      This software allow you to backup a bigger to smaller drive (if the usefull data doesn't oversize the target). --> your needs.
                      It allow you to dump a full HDD in a single file to save it to a server or NAS for example, for backup purpose.
                      It allow you to dig in the image file to recover a single file or folder, without restoring the full backup.
                      Once installed to windows, it allow you to generate a bootable USB key, who allow you to work on disk without their operating system on memory. Not corruption risk.
                      And much more.
                      From all the other software I have ever tried, it's the best one.
                      It's shareware for personal use, no need to crack it.
                      If you want to skip the register step, use this direct URL :
                      Cheers,
                      Phil
                      • russellg2000
                        • Apr 2022
                        Ive used Acronis with good results over theyears, but I like sound of some of the options in this thread, will look to give them a try.
