members any has information on how to fix bad image screen after instaled i think infected software?
dell pc win 7
Delete this application and reinstall and see what happensIf I helped, please consider hitting the Thanks & Rep buttons
Dum question but is your windows 7 32bit or 64 bit ?
Also try this and report
- Select the “Start” button.
- Type “startup”.
- Select “Change advanced startup settings“.
- Select “Restart now” under the “Advanced startup” area.
- Select “Troubleshoot“.
- Select “Advanced Options“.
- Select “Startup Options“.
- Select “Restart“.
- A menu will appear where you can press “7” on your keyboard to choose “Disable driver signing enforcement“.
Now Device Driver Signing should be disabled, allowing you to install any driver you like in Windows 10 until you reboot.[/COLOR]
then i updated the driver manually via device manager and it workedLast edited by accodinguk; 27 September, 2022, 14:40.If I helped, please consider hitting the Thanks & Rep buttons
