internet down after reboot
  • roryson
    • Mar 2009
    • 694
    i have windows 7 and or some reason after i reboot my computer my internet is down. i have a yellow symbol on my internet icon in my system tray and to get internet going again i have to disable and re-enable my adaptor. ive reinstalled windows 3 times now but the error keeps on poping up. any ideas people. its doing my head in
  • cgscott
    • 3513
    Do you have any other devices using the router?
    Patience is a virtue.
    • roryson
      • Mar 2009
      • 694
      i have 1 other pc and 1 htpc. but just thought, i have an iPhone 4 which ive had a week problems started after i got my iPhone
      • roryson
        • Mar 2009
        • 694
        problems started this week
        • roryson
          • Mar 2009
          • 694
          also i reinstall windows from a clean image and it works fine for a while, then after a few reboots from installing software it fails to connect. i dont understand it..........
          • roryson
            • Mar 2009
            • 694
            After playing around I think the problem is my router, not my computer. A couple of weeks ago my computer lost Internet connection and thought I narrowed it down to a dodgy Ethernet cable. Then I got the symptoms again the past dew days and as my HTPC didn't loose the connection I thought it was my computer. Was messing around on my iPhone and couldn't get a wifi signal until I rebooted the router. So I think I need a new router. Do you Lott agree..?
            • enigmas
              • 22
              The yellow symbol usually stands for bad handshake, so even if you have cable connection the system is not able to require the IP address by DHCP, what you can try is to check the router settings, and give him a restart afterward.
              • egyclick
                • 436
                you can change the utp cable ton another port, also in LAN properties have a look and post here what protocols you see
                • roryson
                  • Mar 2009
                  • 694
                  This morning went to local pc shop and bought a pci LAN card and installed it. It worked with the card so I tried the LAN port on my motherboard again and it works fine now. Any thoughts..?
                  • roryson
                    • Mar 2009
                    • 694
                    Still running fine, just found the router that i got from my service provider for free. It's a. D-Link. I'll give that a go if things go bad again...
