system restore
  • standarren
    • 857
    system restore
    hi chaps i have a hp laptop it had vista installed but i installed windows 7 i still have the backup on the hardrive from the original vista but cant seem to load it any suggestions
  • seano123
    • Apr 2010
    • 86
    go in bios change the boot sequence to other partion or hd which has new 7 loaded, or try one of th f keys during boot up for options that way, hope this helps m8
    • dasteph
      • 1293
      did you format the hd then install 7 or do an upgrade from vista to 7.
      is the backup recovery software on a separate partition on the hd.
      what o/s is on the laptop at the moment.
      • standarren
        • 857
        upgraded to windows 7
        in my computer there is a hp recovery partition
        when i clickit nothing is there
        • dasteph
          • 1293
          if you upgraded you cannot downgrade back to vista, if the backup as you call it is recovery software then that is to repair an existing vista o/s.
          if you want to reinstall vista then you must first format the hd then do a clean reinstall from a vista installation disc.
          • james951
            • Oct 2010
            • 6
            hello you can recover your system i using cd install and boot for cd and press repar
            good luck
