gilinx.exe
  • ecufix
    • Feb 2010
    • 2214
    gilinx.exe
    Hi Guys
    I ve been infected with gilinx.exe
    It has created shortcuts of all my folders that does not exit
    i can see by looking at the size of the file that the data is still there.
    if i try rename it ,iam told the path or filename is incorrect or does not exist
    please advise if there is a remedy
    regards
    Do what you can with what you have .
    i think thats malware, have you tried malwarebytes ? google it you will find it easy, ( update program before use )
    • ecufix
      • Feb 2010
      • 2214
      can effects be reversed ?
      • ecufix
        • Feb 2010
        • 2214
        Most important info I left out
        This is all happening on an external usb harddrive
        It has been suggested that I use attrib (dos cmd )
        I keep getting wrong parameters errors
        • ecufix
          • Feb 2010
          • 2214
          Solution to Gilinx virus
          As mentioned this virus changes folders to invalid shortcuts.
          I found a way to retrieve my data by using easy recovery software. I selected disk diagnostics and then size manager which allowed me to see that the data was still there , then copied it to a new location .easy
          thanks regards
