This free tool supports a limited range of MEP's but many of you will still find it useful. If this tool does not support your phone (i.e. MEP not found) then you'll need to post a request in the Blackberry unlock code section once it is up and running again!
If you already have your MEP and IMEI then jump to Step 8/9 and enter the IMEI manually and select the MEP from the drop down menu.
1. Install Blackberry Desktop manager. If you don't have it visit: Cell Phones, Smartphones & Mobile Phones from BlackBerry.com you'll find it there!
2. Download the unlocker: Digital Kaos - Downloads - BlackBerry Unlocker
2a. Newer version can be found here: http://www.digital-kaos.co.uk/forums...ml#post1499582 no password for this version!! <<<--- NEW <<<---
3. Un-RAR the file using the Password: fromdigitalkaos
4. Just copy the files into a directory (folder) of your choice.
5. Run the program BlackBerryTools_2.exe
6. Connect handset, wait for drivers to load and then click MEP Reader (1).
7. Then click on MEPReader button (2).
8. Now click on Blackberry Tab (3). Check MEP and IMEI are correct - If not enter the correct details.
9. Then click on Calculate (4).
10. To find out how to enter your code click on MEP Reader Tab (5) and then on HOW TO button (6).
11. Follow the instructions given for your handset.
Please do not attempt to post comments in this thread as it should be self-explanatory. If you can not follow these instructions the do not use the software.
Note: Unless you have at least one valid forum post you can not download the file!
