hi guys lookin for some help here i have a bb 9300 but when i try to put the dash in for the mep number it wont let me?????????????????????????
inserting mep into blackberry curve 9300
What dash?
If you have been given a MEP2 code to unlock the phone you just have to insert a different network SIM & turn on.
The phone will ask you if you want to unlock the phone. Then you just type the code in.
If you are trying to get your MEP code so you can generate an unlock code, there are easier ways.
There's a MEP reader somewhere in the PDA/Mobile section attached to a closed Blackberry unlocking thread. You can still download the program.
Or you can post your IMEI & PRD code & I'll give you the MEP2 code.Canker
- The Baby Eating Bishop of Bath & Wells[COLOR=Green] -
The MEP reader only reads a protection code from the phone. That MEP code is used along with the IMEI to generate the unlock codes.
The MEP code you have is not the unlock code.
Post your IMEI & either the MEP code you have or the PRD from the sticker under the battery. I'll get you the unlock codes.Canker
IMEI : 356319040966438
MEP : MEP_09292_006
Calculating..
MEP1 (SIM) : 71 45 56 02 09 53 35 53
MEP2 (NETWORK) : 84 50 51 89 34 40 03 86
MEP3 (NETWORK SUBSET) : 52 59 14 28 01 83 58 46
MEP4 (SERVICE PROVIDER) : 41 81 37 32 82 93 71 73
MEP5 (CORPORATE) : 90 39 32 18 76 79 54 76
Spaces in codes are just for clarity and should not be entered!Comment
Hello Everyone,
I have a similar problem. I have a BB 9630 which was formerly used with Verizon and would like to unlock the phone to use an AT&T sim. I found out the mep code which is in the format of xxxxx-xxx. The code doesn't work and I think it may be because of the dash in the code which I can't figure out how to type. I've tried all 8 digits and also tried only the first 5 digits with no success. Any ideas guys? Thanks.Comment
Hello Everyone,
The MEP code and IMEI are used in conjunction with each other to generate the unlock code. The unlock code will be either 8 or 16 digits long! The MEP is NOT the unlock code!!Comment
http://www.digital-kaos.co.uk/forums...g-tool-248342/ do it yourself hereany information provided is for educational/experimental purposes only.Comment
Blackberry 9300.mep code
Hi there.....
Please I need help.....!!!
I need the MEP code for the blackberry 9300 ?
IMEI :355894040812411
PRD : 29973001Comment
dont know wot id do without this site.
