Micro SD for Nuvi 1410.
  • craigyj
    • Feb 2010
    • 118
    Evening,
    can anyone tell me the correct Micro SD card for my Garmin Nuvi 1410? I need to know the biggest capacity that will work without compromising speed. I want to install the latest Europe maps which is a shade under 4gb. All help appreciated.
    Craig, Nottingham.
  • teerak2uk
    • Apr 2009
    • 6074
    I run a 4gb in my 1340 and is fine where you getting your map from ?
    Oh and by the way if my post has been at all helpfull
    please press the little THANKS tab
    • Jim.Mahoney
      • Feb 2010
      • 4249
      I'd recommend using only Sandisk or Transend microSD. The 'unbranded' ones can lead to issues including data loss!!
      • craigyj
        • Feb 2010
        • 118
        Thanks for the replies; Garmin have replied and they recommend a maximum of 16gb. I won't be putting one in, will put maximum 8gb to keep the speed of the unit top notch. If anyone has any suggestions as to where I can obtain my software from I would be most grateful. I have a few places in mind (some off DK) and elsewhere. I just want the most reliable source if you get my drift.
        Best wishes, Craig, Nottingham.
        • teerak2uk
          • Apr 2009
          • 6074
          GPS Underground :: Your Tracks Guide and create a folder called garmin on your SD and download an unlocked image and place inside the folder but any probs there are some good tutorials there
          • craigyj
            • Feb 2010
            • 118
            Oredered an 8gb Sandisk and no doubt will be seeking everyones invaluable help when it arrives.
            • craigyj
              • Feb 2010
              • 118
              My card finally arrived today. I'm in the process of trying to do this myself but if I blob it hope someone can help!!
              • craigyj
                • Feb 2010
                • 118
                Right, I've downloaded the latest Europe maps as unlocked img. file and created my Garmin folder in the SD card. I dragged and dropped the downloaded files into the Garmin folder and then popped it into my sat nav. The question I have is how do I know if this has been sucessful ? When I connect the device to my laptop I can see both the pre-installed software and the SD card contents. Can I access the SD card from the unit itself or does the SD card when installed override the installed software ? I would really appreciate some help.
                • craigyj
                  • Feb 2010
                  • 118
                  Pleeeeeeeeease help !!!!!
