Hi quality FRESAT BOX required
  • clem58
    • Aug 2009
    • 819
    I plan on disconnecting VIRGIN and installing a FREESAT BOX. Can any of you guys recommend a good quality FREESAT BOX i'm interested in a box that has a good quality upscaler. I don't know much about them but i would want a good HHD at least 300GB. Any and all advice would be welcome.
  • cactikid
    • 12017
    virgin is cable receiver,and freesat use a dish.
    may also depend how may tuners you want.
    freesat+ HD TV recorder - freesat
    • clem58
      • Aug 2009
      • 819
      SAMSUNG SMT-S7800 500GB Freesat+ HD Digital Recorder | Dixons |
      I found this box, can anyone tell me if i can get a better thanks in advance for replies
      box. Its the samsung smt
      • clem58
        • Aug 2009
        • 819
        Could u explain the benifit of havin one tunner or a havin a dozen. would it be pickin up mainly foriegn language channels. Obviously i would need a rotating dish. Please enlighten me. thanks for ur replies
        • nibblitz
          • May 2010
          • 1300
          The Freesat box you put up is a good box, but quite exepnsive, I think you could maybe find much cheaper..
          A recorder needs 2 tuners to enable you to watch a different channel to that what you might be recording.. If the recorder only had one tuner you would only be able to watch the same channel you are recording..
          Why do you think you need a "rotating dish"? Freesat comes from just one position in the Sky, the same position Sky TV comes from.. If you have a Sky dish you can plug into that and get Freesat.. You will only need a "rotating dish" if you wish to receive many foriegn TV stations from many other satellite positions in the sky, but you would need a totally different type of satellite receiver as a Freesat box will not normally allow you to do this..
          • clem58
            • Aug 2009
            • 819
            Yea thats a good post. That box i posted is one i might find reliable don't want mishaps a few mths down the line. Freesat channels was all i was interested in just couldn't figure the tuners bit (was always afraid to ask at risk of sounding daft) So i'm after watch one record at least one other channel. which is what i can do with virgin box. Can't wait to tell them to f##k off. Now all i need is a good internet provider that won't interfer with wot i download BT is out and to many complaints about TALK TALK any suggestion? thanks for your post. Take care n be safe
            • alex123
              • 832
              the best freesat box is the humax twin pvr its always been the best
              • clem58
                • Aug 2009
                • 819
                I plan on runnin 3 boxes of my dish, can you tell me which type of splitter i'll need and is quality really that relevant?
                Also i found this little gem, if i plum for this wee job would replacing the HDD FOR A 1tb be aq bit risky?
                Thanks alex123 your advice has been taken.
                Last edited by clem58; 30 September, 2011, 18:41. Reason: additional info required
                • nibblitz
                  • May 2010
                  • 1300
                  If you intend running 3 recording boxes then you'll need an LNB on your dish with enough connections, not splitters.. For each recorder will need two feeds from the dish, so you'll need an Octo LNB... A Twin tuner recorder requires two individual feeds from the satellite dish, a single tuner Freesat box just requires one feed...
                  • clem58
                    • Aug 2009
                    • 819
                    Just so happen i have one. ta for ur elp
                    • alex123
                      • 832
                      your welcome m8 humax products have always been great
                      • clem58
                        • Aug 2009
                        • 819
                        Humax fresat
                        This maybe a long shot, but i been lookin around the specs of the humax fresat box and was wonnderin if there was the possibility of finding one that i can hook an external hdd to (usb), or am i bein greedy. Thank in advance for replies
                        • clem58
                          • Aug 2009
                          • 819
                          Fresat packages
                          Are sky sports pay perview or movie packages available on fresat
                          • alex123
                            • 832
                            no thats why its called freesat no paychannels
