Diablo Cam Underworld Files
hi m8,
the file is ok first download it to your desktop then
open the folder and take the data file out ready to load
now opem the cas software and then go to the panel for loading
the cam and click the cam file system button at the top of the panel
then click the connect bar at the top when you see both green arrows
at the right hand side of the local files box [bottom left] lit up
in that box you should see the opened data file highlight it and click
the arrow pointing to the right a box will open saying the file exists
do you want to over write it say yes and you will see a bars strip loading
the file then exit the cas software and the chns will openPlease Read Carefully!
original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish,Comment
DIABLO KEYS BIN 28/1/09
the following keys added 28/1/09
Dream TV 00-01 Keys [146?E]
Kabelkiosk CWs added
JSC Sports +1,+2 DCW Keys [13?E] >11179 H 27500 3/4
JSC Sports +4 DCW Keys [13?E] >11296 H 27500 3/4Last edited by benny/9; 29 January, 2009, 19:51.Please Read Carefully!
digialb data bin 29/1/09
New data bin for Diablo and Qbox 29/01/09
Updated : Digitalb tested workingLast edited by benny/9; 10 February, 2009, 10:58.Please Read Carefully!
new 1.59 underworld file 4/2/09
What's New??
SexView is gone.....but...take a look on 9E
all other emulators are updated
i have tested this file and found that digialb does'nt open for me.
the conax chns on 1w and 9e and 8w are all opening
if you load this you will get everything but digialb
and this will keep you viewing untill there is a digialb fixLast edited by benny/9; 10 February, 2009, 10:58.Please Read Carefully!
*************************************************Originally posted by terrierscheers benny..works a treat
as soon as i get the digialb data bin i will post it,Please Read Carefully!
New data bin for Diablo U/W 1.59 and Qbox 05/02/09
Updated : Digialb (Conax 16E) tested workingLast edited by benny/9; 10 February, 2009, 10:58.Please Read Carefully!
Latest data bin change 6/2/09,
whats new:
- Underworld 1.59 compatible
- JSC Sport 1,2 and 4 CCW keys added (Turn Fixed CW ON)
- AKTA CCW keys added (Turn Fixed CW ON)
- data.bin (Conax keys update)
- Kabel Deutschland 23.5?E (nagravision 2): OK
- MTV Networks 19?E (conax): OK
- DigitAlb 16?E (conax): OK
- DigitAlb HD 16?E (conax): down
- RTVi 13?E (conax): down
- SexView 13?E (irdeto 2): down
- FreeX TV 13?E (irdeto 2): down
- Canal Digital Nordic 1?W (conax): OK
- Canal Digital Nordic HD 1?W (conax): OK
- Digi TV 1?W (nagravision 2): OK
- KabelKiosk 9?E, 8?W (conax): OK
- ORF 1, 2, HD 19?E (cryptoworks): OK
- Euro 1080 HD 7?E (irdeto 2): OK
- SEX 9?E (irdeto 2): OKLast edited by benny/9; 10 February, 2009, 10:58.Please Read Carefully!
diablo 1.60 9/2/09
diablo 1.60 9/2/09
What's New??
a full update
all other emulators working are updated
this file is teated workingLast edited by benny/9; 17 February, 2009, 12:31.Please Read Carefully!
did you format the cam before loading the 1.60 file?
if you did you need to re set the configuration menuPlease Read Carefully!
good afternoon all and mr benny/9, had a look at 160 again you will not believe this benny was right thank you m8,cas3 said no room for file i tried to remove some files in r,hand pane to make room for 160 must altered format,so closed 86b and downloaded 86c + 160 everthing working great, please go to my club in warrington get 1/2 bitter on my slate.Comment
**************************************good afternoon all and mr benny/9, had a look at 160 again you will not believe this benny was right thank you m8,cas3 said no room for file i tried to remove some files in r,hand pane to make room for 160 must altered format,so closed 86b and downloaded 86c + 160 everthing working great, please go to my club in warrington get 1/2 bitter on my slate.
i guess you were trying to load the dup file like a data file?
anyway i'm please you sorted it mate, i know the file was working first class unless you have a problem you dont need to format the cam between files they just over write each other and this does'nt change the cam config
you have a club in the capital of the north west,
i get about there some times are there any pubs left there now everywhere they are closing down and you lost the breweries as well. i think there's a tesco on there land now
