Diablo Cam Underworld Files
  • benny/9
    • 1964
    #31
    underworld 1.61 16/2/09
    underworld 1.61 tested working
    canal+nordic on 1w and digialb on 16e fixed
    ?Version 2.3 ONLY? Conax: Canaal Digital Nordic - Thor 3/5 0.8W>>>ok
    ?Version 2.3 ONLY? Conax: DigitAlb - Eutelsat W2 16.E)>>>>>>>>>>ok
    ?All Vers.? Irdeto2: Free X TV - Hotbird 6/7A/8 13E>>>>>>>>>>>>>ok
    ?Version 2.3 ONLY? Irdeto2: M*T on 9E>>>>>>>>>>>>>>>>>>>>>>ok
    Conax: Kabelkiosk -on 9E and 8W are down waiting a bib file>>>>>>DOWN
    there are also in the zipped folder that you load after the u/w dup cam file
    there is a digialb data bin file and a s2_nl bin file
    for digi-tv and the nl chns on astra 19e
    the data bin only works on underworld 1.61 file
    Please Read Carefully!
    • mulvihc
      • 50
      #32
      Underworld 1.61 & Data file
      I have loaded both the DUP and data files and can open Digialb but cannot open Digi TV or NL channels on 19e. I have a Humax 5400. Any suggestions.
      • mulvihc
        • 50
        #33
        Underworld 1.61 and data file.
        I have played around with the Diablo. I have formated and reloaded and now I am not able to open any channel and get a smartcard message telling me to please insert my card. Any help would be welcome.
        • bassethound
          • 65
          #34
          You must format twice load underworld 1.61 and add the NEW bin file.
          you have to go into the cams menu, enter the configuration sub menu and then turn Emulators to ON.
          Are you using the latest Cas Studio 8.6c?
          • mulvihc
            • 50
            #35
            Humax 5400 problem.
            Thanks Bassethound. 1 further question before I start. For the 161 files posted above I cannot open them with WinZip. I keep getting message "Cannot open file: it does not appear to be a valid download". I am using the wrong WinZip file to open ?
            • mulvihc
              • 50
              #36
              Humax 5400 problem
              In the Cam File System I see the EMU menu. How do I turn it on. When I left or right click it opens 2 files TABLES and NAGRA. I do not see the option to turn it on. Please help.
              • benny/9
                • 1964
                #37
                after you have loaded the 1.61 dup file and then the data file
                put the cam in the receiver slot and turn on
                press menu and>go to common interface and you will
                see the file name ie:underworld 1.61 highlight it
                and click>ok on the next panel go to [4] configuration
                and click>ok on the next panel set the configuration
                to the following settings useing you vol and chn buttons
                on your remote to scroll and change the menu's
                [1] language [english]
                [2] caids file [caids]
                [3] PMT - [on]
                [4] emulators [on]
                [5] N2 AU [off]
                [6] Emu priority [1:emu-2:cards]
                [7] fixed cw [on]
                [8] Smartcard mess [show never]
                [9] adminstrator menu [ do not change anything in this ]
                after you have set the cam config to the above settings
                exit the menu and turn the receiver off and on again to
                lock the settings in the cam menu,now the chns will open.
                and you dont have to format the cam everytime you load
                a new file the files overwrite one anouther
                if you do format the cam you loose all your cam settings
                and then you need to do the above again
                • benny/9
                  • 1964
                  #38
                  i take it your channels are now open?
                  here you go i will post a bit extra for you to test
                  thats if the matron allows you to view these channels
                  • benny/9
                    • 1964
                    #39
                    New data bin for Diablo and Qbox 18/02/09
                    Update : TSA/SCT (9?E/13?E)
                    In order to make the channels open
                    before to select a bouquet channel
                    you have to select a channel thats free to air
                    • benny/9
                      • 1964
                      #40
                      New data bin for Diablo and Qbox 18/02/09 (Second Update today)
                      New data bin for Diablo cam and Qbox
                      whats new on this file
                      Updated KabelKiosk on 8w and 9e plus M*t 9E
                      • khan
                        • 46
                        #41
                        digitv 1w
                        hi is digitv open on 1w????
                        • benny/9
                          • 1964
                          #42
                          yes turn the n2 A/U off in the configuration on the cam
                          • benny/9
                            • 1964
                            #43
                            new underworld 1.62 27/2/09
                            What's New??
                            Fixed all the emulators
                            XclusiVe E M Us
                            ?Version 2.3 ONLY? Irdeto2: MCT (9.0?E)
                            ?Version 2.3 ONLY? Conax: Canaal Digital Nordic - Thor 3/5 (0.8?W)
                            ?Version 2.3 ONLY? Conax: DigitAlb - Eutelsat W2 (16.0?E)
                            • benny/9
                              • 1964
                              #44
                              Re: UnderWorld DATA.BIN 28/2/09
                              UnderWorld 162 DATA.BIN + S2_NL.BIN missing in last firmware
                              UnderWorld 162 DATA.BIN works only under Underworld 1.62
                              Exclusive E M Us Fixed
                              ?Version 2.3 ONLY? Irdeto2: SEX/SCT S1-3 Eurobird 9A (9?E) & Hotbird 8 (13?E)
                              ?Version 2.3 ONLY? Conax: Digit Alb - Eutelsat W2 (16?E)
                              ?Version 2.3 ONLY? Conax: MTV Unlimited - Astra 1M (19.2?E)
                              ?Version 2.3 ONLY? Conax: DaVinci Learning - Sirius 4 (4.8?E)
                              ?Version 2.3 ONLY? Conax: SSN TV - SuperSports Network - Atlantic Bird 1 (12.5?W)
                              • Techrigger
                                dont know what im doing wrong but i cant get the diablo cas3 to see these files. Also get an unexpected end of archive message if i try to extract them. Is there anything I am doing wrong... do I need to load anything else first.
                                Ok now solved, had to use firefox to download....
