Does anyone know why I can't get transponder 10.756V 27.498 16e, on my technomate 5400. Also getting a really weak signal on most transponders. Seems to only be this satellite, all others are in the high 80-90s. Thanks
Transponder help !
16east
eutelsat have been having alot of problems with the w2 sat at this position and this is why your signal levels have gone down. i take it your after the digitalb channels so why dont you try a detailed blind scan in the 10.700-10.950 freq range and you could also try a network search using 11.658.h.27900..2/3 as the starting transponder. if all this fails then the go to 10 degrees east satellite(eutelsat w2a) and scan 11.346.h..27500..7/8 as digitalb supersports are broadcasting from there at the moment because of the problems at 16 east.DM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30W
