To identify if your openbox is original or clone
  • cbmc
    • Jul 2011
    • 4
    #31
    Originally posted by darvash
    Hello, Everyone :
    If you have Openbox/Skybox S9(S10) HD PVR with Ali3602 BGA. To identify if it is original or not as follows:
    1. Backup up your current firmware
    press menu---tool---dump by usb
    Save your dump file
    2. Upgrad to new software (attatched file 17_06_11.rar)
    3.press menu---tool---information(press ok)---press 777777 key (888888 if S10)
    If chip ID is one of these numbers
    00D0
    00EA
    085B
    0D0C
    98A1
    98F2
    9CF4
    9D1A
    Congratulatations! your HD Receiver is original!! You can experience and enjoy much more more new functions.
    If your box ID don't match, please upload old firm again before rebooting max 10 times otherwise , your HD receivers will be killed!!
    hi just got a s10 iv checked other forums for clone or not, and u do not have to dump and install. you just go.....tools /info /8888.....and chip dispays.
    • darvash
      • Aug 2009
      • 51
      #32
      Correct If you have a firmware later than 07/04/2011 you don't need update firmware but if you have a box with older firmware than 07/04/2011 so you get the wrong ID
      *****Don?t argue with idiots. They drag you down to their level and beat you with experience*****
      • antolioni
        • Oct 2010
        I have also 2 clones with original firm 05-05-11 and a chanellist from a S9 . Every time reboot or locked . Satelite scan doesn't work after 7% or sometimes 12 % it stops. Is something wrong with the chanellist S9 that it not work in S10
        • darvash
          • Aug 2009
          • 51
          #34
          Witch satellite you are trying to scan? You can upgrade channel list by flash disk ( safe for clone boxes)
          • davehead
            • Jul 2011
            working firmware
            hi guys does this firmware kill cloned boxes
            • darvash
              • Aug 2009
              • 51
              #36
              Just upgrade with this firmware and if "Your Box is CLONE version!!!" massage warning appear before rebooting 10 times so quickly degrade to previous software (if you have remembered to save it) by Dump by usb
              • southpaw
                • 2233
                #37
                my supplier assured me my boxes were originals , however chip id is 1015 (post one dont list 1015 so one would assume clone), after googling about it seems the list in post one is not up-to-date , and the list of numbers grows increasingly , here is a recent list i got
                • 00D0
                • 00EA
                • 085B
                • 0D0C
                • 98A1
                • 98F2
                • 9CF4
                • 9D1A
                • 1015
                • darvash
                  • Aug 2009
                  • 51
                  #38
                  • 00D0
                  • 00EA
                  • 085B
                  • 0D0C
                  • 98A1
                  • 98F2
                  • 9CF4
                  • 9D1A
                  • 1015
                  Thanks to southpaw. first post is now updated
                  • scotsman1
                    • Aug 2011
                    • 10
                    #39
                    I am new to this forum and I tried the 8888 and my chip id was 1015 so it looks like i have a original box is that true.
                    regards
                    scotsman1
                    • southpaw
                      • 2233
                      #40
                      Yep. 1015 is a legit box mate
                      • james77
                        • Aug 2011
                        • 4
                        #41
                        Hello, Everyone :
                        If you have a firmware later than 07/04/2011 go to step 3, otherwise
                        Save your dump file
                        2. Upgrad to new software Download her
                        00D0
                        00EA
                        085B
                        0D0C
                        98A1
                        98F2
                        9CF4
                        9D1A
                        1015
                        Congratulatations! your HD Receiver is original!! You can experience and enjoy much more more new functions. If your box ID don't match, please upload old firm again before rebooting max 10 times otherwise , your HD receivers will be killed!!
                        Tested and i am 100%. CHIP ID 0D7E, is a legitimate chip id of a 100% ORIGINAL S10 OPENBOX
                        • anemar
                          • Aug 2011
                          how can i see my receivers firmware version?
                          In menu-information?
                          thank you
                          • ShaGGy
                            • 27
                            #43
                            Hello, Everyone :
                            Save your dump file
                            00D0
                            00EA
                            085B
                            0D0C
                            98A1
                            98F2
                            9CF4
                            9D1A
                            1015
                            This information is outdated now as some boxes (S10) will still show a valid code even though they are clones (I know because it has happened to me )
                            The only true way to check if you have a clone or not is to install the 08-08-11 firmware then do the above check, in my case all other firmwares reported 00D0 (ie Non clone) but the August updates show me FFFF and if i try all the 8's again it then changes to 00D0, it appears that the Clone box is trying to FAKE the CCID but the new August firmwares can detect this.
                            My box is being exchanged tomorrow as my supplier was also caught out by this and now has new stock that are genuine.
                            • richardsb
                              #44
                              original or clone
                              thank you
                              my chip says OD7E
                              • dluisi
                                • 60
                                #45
                                Here is an up to date list of codes from stbhd.com
                                How to identify clone Ali3602 HD Receiver - How to identify clone Ali3602 HD Receiver - STBHD Forum - Powered by Discuz!
                                if you have an Ali3602 HD Receiver like S9,S10...there has a method to identify if it is original (quality goods) or clone.
                                Before identify , please backup your old software on the box by usb. Download
                                SKYBOX_S9S10_110815.rar upgrade it by usb.
                                enter menu---tool---information---press "8888" key, now you will see CHIP ID , If the box CHIP ID is in the chip_id_list, congratulatation, your HD Receiver is original version! You can upgrade any new firmware to experience more new functions. Otherwise, You Box is clone version , please recover the software with the old version! This software will kill the clone box when power on over 10 times. If less than 10 times, no kill for clone verion.
                                the chip_id_list is the following, it will update everyday: (updated date :08/15/2011)
                                00D0
                                00EA
                                085B
                                0D0C
                                98A1
                                98F2
                                9CF4
                                9D1A
                                1015
                                0D7E
                                38EC
                                When you buy a new box , try to view the chip_id_list on this http page. If you can not find the valid "CHIP ID" on the chip_id_list, it means your box is a clone box.
                                Hope this helps
                                http://giffgaff.com/orders/affiliate/dluisi
