To identify if your openbox is original or clone
Correct If you have a firmware later than 07/04/2011 you don't need update firmware but if you have a box with older firmware than 07/04/2011 so you get the wrong ID*****Don?t argue with idiots. They drag you down to their level and beat you with experience*****Comment
Witch satellite you are trying to scan? You can upgrade channel list by flash disk ( safe for clone boxes)*****Don?t argue with idiots. They drag you down to their level and beat you with experience*****Comment
Just upgrade with this firmware and if "Your Box is CLONE version!!!" massage warning appear before rebooting 10 times so quickly degrade to previous software (if you have remembered to save it) by Dump by usb*****Don?t argue with idiots. They drag you down to their level and beat you with experience*****Comment
my supplier assured me my boxes were originals , however chip id is 1015 (post one dont list 1015 so one would assume clone), after googling about it seems the list in post one is not up-to-date , and the list of numbers grows increasingly , here is a recent list i got
- 00D0
- 00EA
- 085B
- 0D0C
- 98A1
- 98F2
- 9CF4
- 9D1A
- 1015
Thanks to southpaw. first post is now updatedmy supplier assured me my boxes were originals , however chip id is 1015 (post one dont list 1015 so one would assume clone), after googling about it seems the list in post one is not up-to-date , and the list of numbers grows increasingly , here is a recent list i got
- 00D0
- 00EA
- 085B
- 0D0C
- 98A1
- 98F2
- 9CF4
- 9D1A
- 1015
Tested and i am 100%. CHIP ID 0D7E, is a legitimate chip id of a 100% ORIGINAL S10 OPENBOXHello, Everyone :
If you have Openbox/Skybox S9(S10) HD PVR with Ali3602 BGA. To identify if it is original or not as follows:
If you have a firmware later than 07/04/2011 go to step 3, otherwise
1. Backup up your current firmware
press menu---tool---dump by usb
Save your dump file
2. Upgrad to new software Download her
3.press menu---tool---information(press ok)---press 777777 key (888888 if S10)
If chip ID is one of these numbers
00D0
00EA
085B
0D0C
98A1
98F2
9CF4
9D1A
1015
Congratulatations! your HD Receiver is original!! You can experience and enjoy much more more new functions. If your box ID don't match, please upload old firm again before rebooting max 10 times otherwise , your HD receivers will be killed!!Comment
This information is outdated now as some boxes (S10) will still show a valid code even though they are clones (I know because it has happened to meHello, Everyone :
Save your dump file
00D0
00EA
085B
0D0C
98A1
98F2
9CF4
9D1A
1015
The only true way to check if you have a clone or not is to install the 08-08-11 firmware then do the above check, in my case all other firmwares reported 00D0 (ie Non clone) but the August updates show me FFFF and if i try all the 8's again it then changes to 00D0, it appears that the Clone box is trying to FAKE the CCID but the new August firmwares can detect this.
My box is being exchanged tomorrow as my supplier was also caught out by this and now has new stock that are genuine.Last edited by ShaGGy; 19 August, 2011, 01:59.Comment
Here is an up to date list of codes from stbhd.com
How to identify clone Ali3602 HD Receiver - How to identify clone Ali3602 HD Receiver - STBHD Forum - Powered by Discuz!if you have an Ali3602 HD Receiver like S9,S10...there has a method to identify if it is original (quality goods) or clone.Hope this helps
Before identify , please backup your old software on the box by usb. Download SKYBOX_S9S10_110815.rar upgrade it by usb.
enter menu---tool---information---press "8888" key, now you will see CHIP ID , If the box CHIP ID is in the chip_id_list, congratulatation, your HD Receiver is original version! You can upgrade any new firmware to experience more new functions. Otherwise, You Box is clone version , please recover the software with the old version! This software will kill the clone box when power on over 10 times. If less than 10 times, no kill for clone verion.
the chip_id_list is the following, it will update everyday: (updated date :08/15/2011)
00D0
00EA
085B
0D0C
98A1
98F2
9CF4
9D1A
1015
0D7E
38EC
When you buy a new box , try to view the chip_id_list on this http page. If you can not find the valid "CHIP ID" on the chip_id_list, it means your box is a clone box.
