FTP tool for openbox S9 HD PVR
try this ip : 192.168.0.2I am trying to reflash my opebox because I loaded a .abs file that has a password I cannot access or use the usb upgrade.
So I download and unzip the STBHD_LAN_MM.rar file, I unzipped, run the program STBHD_LAN_MM and set the Box IP (192.168.000.002)
Then I Entered the Password, the default Password is [0 0 0 0]
I got the message wait 20 seconds then I got message cannot connect
Help What can I do. I have tried the USB to Null rs232 cable but also failed.
I appreciate any help, THANKSComment
Hi I have tried the LAN tool but only seems to be any good for uploading the CCcam.cfg file. Is there a tool to that will allow you to download the config amend it and then upload? The reason I ask is because the first 3 servers were added by the supplier of the box and I am unable to get the detail of them. I am therefore worried that if I over write the config file I will lose these settings forever. Thanks for any help that can be offered.Comment
You can use the tool to transfer your Cccam.cfg from the box to your STBHD_LAN folder. After you have done that, select the Cccam.cfg file from the left hand menu, in the viewing pane below you will see the contents of the Cccam.cfg file, from here you can edit the file, copy it's contents and do what the hell you want with it before transferring back to the box.Hi I have tried the LAN tool but only seems to be any good for uploading the CCcam.cfg file. Is there a tool to that will allow you to download the config amend it and then upload? The reason I ask is because the first 3 servers were added by the supplier of the box and I am unable to get the detail of them. I am therefore worried that if I over write the config file I will lose these settings forever. Thanks for any help that can be offered.
It's not rocket science, but a little common sense helps.
Hallo everyone
Her is the tool to configer your openbox from PC "only windows"
(Directions are taken from another forum, so no thanks to me but goes to the author for doing this good work)
We shall presume you have already installed firmware dated 06/05/11 or newer, if not you can download the latest firmware for openbox/skybox S9 and S10 her.
Note-: This tool only works if your box is working normaly. If your box seems to be dead and you can not contact it form Pc so hopfully you can still fix it using null modem cable. Just follow this guide
The first thing you will be required to do is download and unzip the
STBHD_LAN_MM.rar file, which can also be downloaded from bottom of page
Once unzipped, run the program STBHD_LAN_MM and set the Box IP,
if you don't know the Box IP, use the remote control and click
Menu -> Network Setup -> and copy the IP Address as that is the Box IP.
Here's an example of what the IP Address will look like: 192.168.0.55
Now Enter the Password, the default Password is [0 0 0 0]
Once you have established a connection, you will see two windows.
The one on the right , that one is the Box File List [the receiver]
The one on the left that one is the Local File List
[this is where the files are located that wish to transfer to the receiver]
If you want to backup your current firmware and cannellist (always a good idea) , mark the files image.abs and TP_PROG.dbs click on the upper arrow < to transfer the file to the Local File List. Save files in a different folder when finished
To add files to the Local File List, first open the STBHD_LAN_MM folder,
and then simply place the files you wish to transfer in the folder.
Notic: If you want to update your box simply rename the firmware file to image.abs and place it in STBHD_LAN_MM folder.
To transfer a file from the Local File List, in this example it will be the Softcam.key,
click on the CCcam plug file, and then click on the Softcam.key file,
and in the bottom window, the contents of the file will be displayed,
also any relevant transfer details will also be displayed in the window.
Now click on the bottom arrow > to transfer the file to the Box File List,
it will then be auto transfered to the correct location for you.
Now we shall transfer the Softcam.key from the receiver to the Local File List,
so again click on the CCcam plug file, and then click on the Softcam.key file,
and in the bottom window the contents of the file will be displayed,
Now click on the top arrow < to transfer the file to the Local File List,
To clear the description box of any file info displayed in the bottom window,
simply click on the X button, .
And the file description info has now been removed, as you can see .
Once you have finished transfering files, click on the Exit button,
hi mate,
this dont seem to work
i get a error and the program crashes and closes i have attached picture, would you know
why i am getting this error.
many thanks,
BonesAttached FilesComment
***8221; will appear on the screen indicating the successful connection established.
