FTP tool for openbox S9 HD PVR
  • judasleons
    • Apr 2012
    can I download cccam.cfg file to my pc?
    • slugworth
      • Nov 2011
      • 1064
      #47
      depends on the firmware rev I guess.
      Accounts are hidden on this version,only for uploading!
      • gumsle10
        • Apr 2010
        Originally posted by darvash
        Hallo everyone
        Her is the tool to configer your openbox from PC "only windows"
        (Directions are taken from another forum, so no thanks to me but goes to the author for doing this good work)
        We shall presume you have already installed firmware dated 06/05/11 or newer, if not you can download the latest firmware for openbox/skybox S9 and S10 her.
        Note-: This tool only works if your box is working normaly. If your box seems to be dead and you can not contact it form Pc so hopfully you can still fix it using null modem cable. Just follow this guide
        The first thing you will be required to do is download and unzip the
        STBHD_LAN_MM.rar file, which can also be downloaded from bottom of page
        Once unzipped, run the program STBHD_LAN_MM and set the Box IP,
        if you don't know the Box IP, use the remote control and click
        Menu -> Network Setup -> and copy the IP Address as that is the Box IP.
        Here's an example of what the IP Address will look like: 192.168.0.55
        Now Enter the Password, the default Password is [0 0 0 0]
        Once you have established a connection, you will see two windows.
        The one on the right , that one is the Box File List [the receiver]
        The one on the left that one is the Local File List
        [this is where the files are located that wish to transfer to the receiver]
        If you want to backup your current firmware and cannellist (always a good idea) , mark the files image.abs and TP_PROG.dbs click on the upper arrow < to transfer the file to the Local File List. Save files in a different folder when finished
        To add files to the Local File List, first open the STBHD_LAN_MM folder,
        and then simply place the files you wish to transfer in the folder.
        Notic: If you want to update your box simply rename the firmware file to image.abs and place it in STBHD_LAN_MM folder.
        To transfer a file from the Local File List, in this example it will be the Softcam.key,
        click on the CCcam plug file, and then click on the Softcam.key file,
        and in the bottom window, the contents of the file will be displayed,
        also any relevant transfer details will also be displayed in the window.
        Now click on the bottom arrow > to transfer the file to the Box File List,
        it will then be auto transfered to the correct location for you.
        Now we shall transfer the Softcam.key from the receiver to the Local File List,
        so again click on the CCcam plug file, and then click on the Softcam.key file,
        and in the bottom window the contents of the file will be displayed,
        Now click on the top arrow < to transfer the file to the Local File List,
        To clear the description box of any file info displayed in the bottom window,
        simply click on the X button, .
        And the file description info has now been removed, as you can see .
        Once you have finished transfering files, click on the Exit button,
        dont work for me
        • rramesh5
          • Jul 2012
          Thanks for the utility. Will give it a try.
          • eriklee18
            • Nov 2011
            #50
            mine is m-sat s10, same problems, hopefully this help, tq
            • lee1892
              • Sep 2012
              CANT SEEM TO DOWNLOAD?
              • morscor
                • Jul 2011
                #52
                • mosborne
                  • Oct 2012
                  Any one have any idea of the timeframe for the upgrade to this tool for downloading video? It would be great if it can do streaming too, but I would be happy just for the download capability.
                  • slugworth
                    • Nov 2011
                    • 1064
                    #54
                    I doubt that one
                    • Sukhum
                      • Oct 2012
                      Thank you for your sharing, it is quite useful tool
                      • topcat33
                        • Oct 2012
                        Great, thanks.
                        • tigriuz
                          • Jun 2012
                          download
                          is very dificult donload any files from this web
                          • dacho87
                            • Dec 2012
                            thanks for sharing this, very usefull
                            • cesc
                              • Mar 2013
                              can i update my cline using the ftp?
