Openbox X3 or Skybox F3
  • zooropa
    i have the x3 can you use any wifi dongle or is there a specific type?
    • sharkey22
      • Mar 2009
      • 7
      #32
      Special WiFi dongle.
      You have to use special type dongle, only about ?10 in the UK, reason is WiFi drivers are "hard coded" into the OpenBox OS.
      You could use a Wireless bridge plugged into the OpenBox network socket. That frees up the USB socket for PVR HDD.
      • tshuma
        • Jan 2012
        • 20
        #33
        Originally posted by yorkie98
        I have an F3. I think it an excellent box as a Client box. It cannot be used as a server as yet (although I'm sure this will come) but the box is simple to set up as a client (lines added with remote), it's fast and the PQ is very good, full 1080p via HDMI whereas many of the openboxes have lacked HDMI and had DVI output instead (which does not carry sound).
        Only small drawback for me is the only USB socket is front mounted under the flap so if using an HDD/memory stick for PVR funtionality, or using wireless, the flap must be open.
        There is now a smaller (and aparrently improved) F3 called the M3 which has a rear mounted USB and claims to have a better tuner.
        Actually, the F3 does have a USB port at the back the front one is also a nice feature to have for when you are upgrading and for your subcription line.
        • ebotee
          • Jan 2013
          • 14
          #34
          using system info menu to see what software/firmware you have and comparing it with the latest on the website is the best way to know.
