Hi,
I have received a new openbox S10 yesterday and the Ethernet port on the box is not working.
When you connect an Ethernet cable to the box the lights do not come on so it appears that the port its self is dead. I have tried using different Ethernet cables and also in different ports on the router but still nothing. I have also tried to flash a different firmware to the box but still the same thing.
If you look at the link below the type of openbox that I have is the middle picture with the onboard Ethernet component.
Inside all 3 OpenBox S10 versions
The only reason that I have not completely written it off is when the box is booting up the green light on the Ethernet component flashes once, which makes me think that there may be some way to save it.
Has anyone any ideas? Or suggest a firmware that may make a difference?
Thanks in advance
Thanks in advance
