Hi i have got a skybox f5 running perfect in one room running via homeplugs connected via ethernet cable to my homehub today i tried to connect another box in another room via the same method but didnt work i also tried to connect the box via ehetrnet cable straight to the hub this also didnt work it looks like my hub will only work one box any help would be great many thanks
Skybox f5 problem
Tags: None
Look at the solution found in this thread it might help skybox F5 suspected...
ps don't follow the last 2 instruction: i.e don't reboot>deliver box to new location
Just a suggestion mate If the new box is using the latest firmware version check DHCPis set to on ,as some variants of the new firmware change setting to offHi i have got a skybox f5 running perfect in one room running via homeplugs connected via ethernet cable to my homehub today i tried to connect another box in another room via the same method but didnt work i also tried to connect the box via ehetrnet cable straight to the hub this also didnt work it looks like my hub will only work one box any help would be great many thanksComment
Tried that still didnt work thanks tho mate :-) i have been told that one box will have to be run via wi fi so gonna give that a try fingers crossedComment
are you using official skybox dongle? If not you will get this message on set up page once upon a time most tp- link ones would work with box now it's just the official ,there are limited amount of others but not too sure which. You can get the official ones for a fiver on certain trading site you also need to change modem security to wpa or wpa2. At best wifi on slyboxes is hit & miss .Last edited by samsid; 21 May, 2013, 16:22.Comment
Have you done the wifi setup? reboot the box enter the modem security key ? if the skybox itself won't recognise the dongle & you can't connect via ethernet doesn't look good. Just to check in neywork local setting DHCP is on and the box has a viable ip address?Comment
