Custom logo guide?
  • shadowbroker
    • 28
    Custom logo guide?
    Hello, is there a guide around anyplace for making your own custom boot logos and menu logos for the Skybox/openbox? been looking but cant seem to find one, only been able to find people offering to do them.
    thank you in advance for any help
    If I did help you, or you liked that I tried to help, click the "thank" button on the bottom right of my comment.
    Don't forget to thank help from other users also.
  • boylan
    • Oct 2011
    • 128
    Seen a few people post they will make them for people but nobody has posted a guide, maybe drop them an inbox for the one you want?
    Would be great if we had a guide really
    • damiensk
      • Apr 2010
      • 201
      search for something called bmp to logo,
      BMP to Logo Tool
      How to use:
      Step1: check have following files
      |- bmp to logo.exe ; application
      |- PAL.par ; PAL parameter file
      |- NTSC.par ; NTSC parameter file
      |- README.TXT ;
      Step 2. generate new logo
      1: Put this tool in one fold, for example: D:\BMPtoLOGO\*.*
      2. prepare logo file, it should be 24 bit BMP format, and the size of input BMP file must be
      720*480(NTSC) or 720*576(PAL), and put this file on the same fold of the tool, for example: D:\BMPtoLOGO\*.bmp
      3. Run "bmp2logo.exe"
      Step1: Select "Open" to open D:\logo.bmp
      Step2: enter size of logo in "Size", please do not input "bitrate" (the size is more bigger, the convert picture
      will be more clear)
      Step3: select "Convert" button to generate object file, for example "D:\BMPtoLOGO\*.m2v"
      4. Use upgrade tool or compile main code again to merge this logo file
      it take no ownership in this, thanks goes to others
      • boylan
        • Oct 2011
        • 128
        BMP to Logo Tool
        How to use:
        |- README.TXT ;
        will be more clear)
        Thanks for the program name, the rest is gobbledygook nice try though
        • slugworth
          • Nov 2011
          • 1064
          logo is basically 1 frame of a video file the proper size and format.
          There are programs around that will convert jpegs to .m2v for logo use.
          The trick is to get a jpeg larger than the 720x526 so the end product isn't distorted.
          • reece345
            • May 2013
            sorry I know im going to sound thick here were it says generate logo what do I use. I want to put a pic of my children has the logo
            • slugworth
              • Nov 2011
              • 1064
              I use batch dvd streams converter for all my logo making needs
              http://beginwithsoftware.com/videoguides/BatchDVDStreamsConverter.zip
              • Hadron
                • 2102
                Not sure what you are asking.
                I have used the program above & I cannot see a prompt where it says "generate logo".
                Although I don't know what all the other generated files are for. Mine generated a .ppm file with the same name and size as the original. It also generated q0.U (102KB), q0.V (102KB), q0.Y (405KB), & stat.out (12KB).
