Just updated list "7th August FULL HD" however, channel still says ''Sky Movies 007 HD " and not "Sky Movies Superheroes HD". Downloaded the FULL HD list ,something i did wrong?!
I must read before i post ask questions in the Sattv5 ** Discussion** only thread
And not in the **Channel List Only Thread**
Cwaite Sky Numbered Channel List **Discussion** Thread
Cheers for that however, channel still says ''Sky Movies 007 HD " and not "Sky Movies Superheroes HD". Downloaded the FULL HD list ,something i did wrong?!Leave a comment:
Has Sky Sports 1 HD changed frequency, it says its scrambled. Sky Sports 1 SD is working fine!Leave a comment:
Hi Sattv5
Thanks for the channel list, much appreciated. Just a quick question, channel 103 ITV, when the ITV news is televised and its time for the regional news, im not getting news for my area, the regional news shows Londons regional news. I live in the west midlands, so it should burmingham. coventry regional news, but its not. Is this related to the channel list?
More than likely its that region because of where Sattv5 lives which means when he does a list for himself its obvious that his BBC and ITV locals will be for his region.
Its been said a 1000 times these Guy's who contribute the lists do so for themselves and upload here for the benefit of other members and it is up to said members to use the channel lists, they may not be to your liking ie: wrong regional channels or HD not ordered in a certain way etc..
But thats the way it is if you need one for your local area then i suggest you take a look at Sattv5's how to create a channel list thread: http://www.digital-kaos.co.uk/forums...-f4-f5-354446/ this will enable you to sort out your own regional variation channels and then perhaps you could upload your list for the benefit of the other west midland users which would be jolly nice of you.
ThanksLeave a comment:
Hi Sattv5
Moved Frequency Channels updates 17/8/2013
Sky Movies 007 HD (Channel 304) Temporary rebranding ended today
Sky Movies 007 (Channel 331) Temporary rebranding ended today
Sky Movies Superheroes HD (Channel 304) (Rebranded from Sky Movies 007 HD)
Sky Movies Superheroes (Channel 331) (Rebranded from Sky Movies 007)
Added satellites back to Satellite list ranging from Astra 1c (2.0 East) up to Telstar 12 (15.0 West) making it suitable for multidish setups & Motorised dishes
Fixed the issue Where menu options are greyed out (Antenna Setup/Single Sat Search/Multi Sat Search & TP List)
all are now enabled by default
Leave a comment:
appreciate the good work. makes my awkward box so much easier to handle. how do u delete groups of channels you no longer use from the satlist?Leave a comment:
Thanks for the quick reply,
Yes it was the first time as I've always used my own custom list, but a few friends have these box's and wanted there channels listed the same as sky and wanted favorites as well.
thanksLeave a comment:
Was this the first time you had used this list on your S11? If so, the favourite headings have to be put in manually the first time you install a channel list.
Subsequent updates should retain the headings.Leave a comment:
It's not compatible with the X5 as it use the file extension .bin for channel list, to answer you second question there is no current channel editors that will open the X5 .bin. There are lists out there use google to search.
Truthfully your mate would have been better getting an X3 openbox, F3skybox or F5 skybox insted of the X5 as it is a problematic box and they f*cked up big time with it.
On another note when I load this list onto my s11 the favorite's do not show as Entertainment, lifestyle, movies etc... on the box, instead they are just labeled Favorite 1 Favorite 2 etc....
Is this the same on the X3 F3 and F5 ?.
I just replaced the first 5 channels on it for my region and put the ones that where there into the place where I got my regional channels and saved it as a user database.Last edited by vorlon2257; 16 August, 2013, 10:12.Leave a comment:
Hi, thanks for this great list, please keep up the good work. My friend has an X5 and wants this on there but its not listed as compatible, surely it is? If not does anyone know where he can get a good one? Thanks again :-)Leave a comment:
Channels List updated 13/8/2013
Arise News HD (Channel 519) removed as left Astra 28a
Arise News (Channel 570) removed as left Astra 28a
Sparkle TV (Channel 667) removed as left Astra 28a
QVC Extra (New Channel) (Channel Number 667) Frequency 12032 H 27500
QVC Style (Channel 683)Moved Frequency to 12032 H 27500
TCM 2 (Channel 318) removed as left Astra 28a
TCM +1 (Channel 1073) Moved as now Added to Sky EPG (Channel Number 318)
TCM Western HD (Channel 317) Rebranded back to TCM HD
TCM Western (Channel 341) Rebranded back to TCM
Word Network (Channel 590) Moved frequency to 11390 V 27500
Leave a comment:
QUOTE=Asudha;2052033]I use PVR 800 editor to edit this list make regional tweaks. is there anyway to skip channels using the editor? I know I can do it on the box but I have 5 boxes and use LAN tool to transfer channel list it would be easier to do it al at once[/QUOTE]
I dont think that you can but it's possible to do in MediaBox Studio editor. Have a look here:
The list is set out exactly the same as a sky HD box and the list you have is set out like an SD Box.Hi
Thanks for the channel list.. I have "1st August FULL HD Ordered TP_Prog.dbs Non Adult Update" installed, I've noticed that on mine certain channels are
switched around. Like Sky Family and Sky Family HD are 306 and 333, but they are the opposite way around to the Sky TV guide app on my iPad. Is this correct
or am I missing something? I am new to this, got my box yesterday and uploaded your channel list today.. Thanks for that.. But certain channels are the
opposite to the iPad Sky Guide, HD and SD opposites, etc.
you could use the Sky+ app on your ipad as that will be the same as the list, or this website:
Sky Guide TV Listings - SkyLast edited by sattv5; 13 August, 2013, 17:22.Leave a comment:
Leave a comment:
