DREAMBOX dm500s problem flash
  • freakje72
    • Nov 2011
    dm500 error
    i will try it all to get my dm 500 back to work
    • hamlanon
      • Jan 2012
      ERROR FLASH DREAM 500
      Good evening, I have a dreambox 500 clone and I have tried with image dreamup 1.3.3.4 but there are cops failed flash error RC 1572 992 Box Will Be unusable now thank you for your help
      • petkovski
        • May 2012
        problem with uploading image
        after turning off dreambox500hd, has error message after loading enigma with crash log. How can I fix and with which program to upload which version of image of enigma?
        • LAMBADA
          • Jun 2012
          dm500s
          Originally posted by Curious123
          Try the oldest version of Dreamup you can find and flash this to your box. After flashing the erase image you then need to flash your image of choice.
          Doesen't work to me.
          • bo anas
            • Jun 2012
            I'm having the same problem. any help please
            • barsaat786
              • Jun 2012
              #66
              y i cnt download any file frm here?
              • andy91
                • Aug 2010
                • 3583
                #67
                Time limit before you can download after making a post and if i had my way it would have to be a meaningful post after you you have made an introduction.
                Introduce Yourself
                Andy,
                • phat1
                  • 114
                  #68
                  having the same issue,i flash erased with dreamup.then i flashed with erase file image given a few pages back,but when i try then to flash with a image of my choice i get the same error as everybody else,I want to put commamdo 14.6 on my box,but i get error message,so i cant install it.why is this? Any way around it?
                  • baycisse
                    • Jul 2012
                    i have prob with DM500 it does not respond to the remote control and no image
                      Not much of an explanation of your problem m8, be more specific. Try another remote or reflashing a new image.
                      • PaphosAL
                        Old Git
                        • 1064
                        #71
                        If you see a DreamUp message like "found no valid JFFS2 in image" then it means you're flashing an image like Commando 14.6 that has had the /var_init folder in the root SquashFS partition surgically removed to save space in /var
                        Don't press the <Flash erase> button, just press <Flash>
                        Cheers- AL
                        • bishbash100
                          • Oct 2011
                          Have the same problem with dreamup not "seeing" my old d500s,runnign out of patience with it now
                          • chic.
                            • 1599
                            #73
                            hi m8 welcome to dk
                            have you put the correct box ip in dreamup and selected the com port
                            if i helped hit the thanks btn
                            • limebg
                              • Oct 2012
                              My DM500s says:
                              Unable to read configuration data
                              --- Device Con Power-On Test DevProgram exception
                              SRR0=8x SRR1=8x
                              Die ... :-(
                              After flash with DreamUp
                              Any ideas?
                              • securityforce999
                                • Sep 2012
                                #75
                                After running this exe program, it tries to connect to the internet - only my firewall stopped it?
                                If its a proper patch (with nothing hidden), it should have no reason to connect to the internet - sameway dreamup works without needing an internet connection?
                                I might be a newbie here, but I'm sure as hell not 'wet behind the ears' and have to ask the question WHY it wants to connect?!
                                Such programs make me damn suspicious.
