file transfer
  • bobstack
    • 9
    file transfer
    i iam having difficulty transferring key files to d500 its as if pc is not connected yet dreamup sees the box fine any ideas ?
  • cgscott
    • 3513
    What ftp program are you using?
    Patience is a virtue.
    • aftermath
      • 4345
      you need to hard wire your 500 to your PC, or through a network.
      If a network, make sure your IP is near to the one of your router
      example Router 192.168.1.1 , change box IP to 192.168.1.10 or similar.
      you will need to username and password for your 500
      probably username = root
      password = dreambox.
      you could use FlashFXP or CoreFTP to send files between PC and 500
