DREAMBOX DM800HD MOTOR SETUP
Hi i have Gemeni image install in my box.here is some information how to setup ur box with motorized dish (diseqc 1.2)
First Go to:
Menu--------->Setup------>service searching--->tuner configuration--->Advanced
then choose any setllite you want example we select Hotbird 13 east
Advanced---->hotbird
LNB--->1
USE USALS---->NO
Store --->001
diseqc----->1.2
only change these setting pls dont change any other setting then press ok then exit
same you can did other setllites setting but everytime you add other setllite please select LNB2 AND Store :002 and if you add more settllites pls give them LNB3....AND store :3
then go to Positioner Tuner setup
MENU--->-->Setup------>service searching-->Tuner positioner---->Tuner-
select setllite Example
Tuner positioner---->Tuner--Astra 19east
store postion---->1
then move your your dish east by pressing green button when you get astra signal and say locaked just press green button to store setting.then exit
Now search your astra 19 east by Manual scan and do the same for other setllites just Change store number 1.2.3.4.5. remember all setllites store with different numbers hope this method will work for you.
First Go to:
LNB--->1
USE USALS---->NO
Store --->001
diseqc----->1.2
store postion---->1
