dm 800hdse and it9135 usbdtt
  • kallquk
    • Sep 2011
    Hello,
    I have this model and put latest image of multimedia of 5-december
    Trying to install a usb dtt model it9135, I installed its drivers from feeds, ftp up firmwares required then rebooted.
    Here are logs of dmesg, lskmod, lsusb:
    =~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2015.12.11 20:04:31 =~=~=~=~=~=~=~=~=~=~=~=
    opendreambox 2.0.0 dm800se
    dm800se login: root
    root@dm800se:~#
    root@dm800se:~# dmesg
    300
    [ 0.611000] Block size=00004000, erase shift=14
    [ 0.612000] NAND Config: Reg=04042300, chipSize=64 MB, blockSize=16K, erase_shift=e
    [ 0.613000] busWidth=1, pageSize=512B, page_shift=9, page_mask=000001ff
    [ 0.614000] timing1 not adjusted: 5363444f
    [ 0.614000] timing2 not adjusted: 00000fc6
    [ 0.615000] eccLevel=15, 1Ksector=0, oob=16
    [ 0.615000] nbrBitsPerCell=2, cellinfo=0, chip->cellinfo=00000000
    [ 0.616000] <--brcmnand_set_acccontrol: acc b4: f7ff1010, after: f7ff1010
    [ 0.617000] BrcmNAND mfg ad 76 Hynix HY27US08121A (dream) 64MB on CS1
    [ 0.617000]
    [ 0.617000] Found NAND on CS1: ACC=f7ff1010, cfg=04042300, flashId=ad76ad76, tim1=5363444f, tim2=00000fc6
    [ 0.619000] BrcmNAND version = 0x0302 64MB @00000000
    [ 0.619000] B4: NandSelect=40000202, nandConfig=04042300, chipSelect=1
    [ 0.620000] brcmnand_read_id: CS1: dev_id=ad76ad76
    [ 0.621000] After: NandSelect=40000202, nandConfig=04042300
    [ 0.621000] Found NAND flash on Chip Select 1, chipSize=64MB, usable size=64MB, base=0
    [ 0.622000] brcmnand_scan: B4 nand_select = 40000202
    [ 0.623000] brcmnand_scan: After nand_select = 40000202
    [ 0.624000] page_shift=9, bbt_erase_shift=14, chip_shift=26, phys_erase_shift=14
    [ 0.624000] Brcm NAND controller version = 3.2 NAND flash size 64MB @1c000000
    [ 0.625000] brcmnand_scan: mtd->oobsize=16
    [ 0.626000] brcmnand_scan: oobavail=12, eccsize=512, writesize=512
    [ 0.627000] brcmnand_scan, eccsize=512, writesize=512, eccsteps=1, ecclevel=15, eccbytes=3
    [ 0.628000] -->brcmnand_default_bbt
    [ 0.628000] brcmnand_default_bbt: bbt_td = bbt_main_descr
    [ 0.629000] Bad block table Bbt0 found at page 0001ffe0, version 0x01 for chip on CS1
    [ 0.630000] Bad block table 1tbB found at page 0001ffc0, version 0x01 for chip on CS1
    [ 0.631000] brcmnandCET: Status -> Deferred
    [ 0.632000] Adjust partition complete size from 4000000 to 3f00000 to avoid overlap with BBT reserved space
    [ 0.633000] Adjust partition root size from 3c00000 to 3b00000 to avoid overlap with BBT reserved space
    [ 0.634000] Creating 4 MTD partitions on "brcmnand.0":
    [ 0.635000] 0x000000000000-0x000003f00000 : "complete"
    [ 0.640000] 0x000000000000-0x000000040000 : "loader"
    [ 0.642000] 0x000000040000-0x000000400000 : "boot"
    [ 0.644000] 0x000000400000-0x000003f00000 : "root"
    [ 0.682000] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
    [ 0.686000] ata1.00: ATA-7: TOSHIBA MK1234GSX, AH001C, max UDMA/100
    [ 0.686000] ata1.00: 234441648 sectors, multi 16: LBA48
    [ 0.690000] ata1.00: configured for UDMA/100
    [ 0.691000] scsi 0:0:0:0: Direct-Access ATA TOSHIBA MK1234GS AH00 PQ: 0 ANSI: 5
    [ 0.693000] sd 0:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/111 GiB)
    [ 0.694000] sd 0:0:0:0: [sda] Write Protect is off
    [ 0.694000] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
    [ 0.695000] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
    [ 0.736000] usb 1-2: new high-speed USB device number 2 using ehci-brcm
    [ 0.764000] sda: sda1 sda2
    [ 0.766000] sd 0:0:0:0: [sda] Attached SCSI disk
    [ 1.019000] ata2: SATA link down (SStatus 4 SControl 300)
    [ 9.317000] VFS: Mounted root (jffs2 filesystem) on device 31:3.
    [ 9.320000] devtmpfs: mounted
    [ 9.321000] Freeing unused kernel memory: 220k freed
    >[ 13.740000] udevd[123]: starting version 182
    [ 14.321000] stb_core: module license 'Proprietary' taints kernel.
    [ 14.322000] Disabling lock debugging due to kernel taint
    [ 14.325000] it913x: Chip Version=01 Chip Type=9135
    [ 14.331000] it913x: Dual mode=0 Remote=5 Tuner Type=df
    [ 14.335000] dvb-usb: found a 'ITE 9135 Generic' in cold state, will try to load a firmware
    [ 14.932000] dvb-usb: downloading firmware from file 'dvb-usb-it9137-01.fw'
    [ 14.933000] it913x: FRM Starting Firmware Download
    [ 15.398000] it913x: FRM Firmware Download Completed - Resetting Device
    [ 15.399000] it913x: Chip Version=01 Chip Type=9135
    [ 15.400000] it913x: Firmware Version 204147968
    [ 15.433000] dvb-usb: found a 'ITE 9135 Generic' in warm state.
    [ 15.439000] dvb-usb: will use the device's hardware PID filter (table count: 31).
    [ 15.444000] DVB: registering new adapter (ITE 9135 Generic)
    [ 15.586000] DVB: registering adapter 0 frontend 0 (ITE 9135 Generic_1)...
    [ 15.637000] IR keymap rc-kworld-315u not found
    [ 15.637000] Registered IR keymap rc-empty
    [ 15.638000] input: IR-receiver inside an USB DVB receiver as /devices/platform/ehci-brcm.0/usb1/1-2/rc/rc0/input0
    [ 15.643000] rc0: IR-receiver inside an USB DVB receiver as /devices/platform/ehci-brcm.0/usb1/1-2/rc/rc0
    [ 15.644000] dvb-usb: schedule remote query interval to 250 msecs.
    [ 15.645000] dvb-usb: ITE 9135 Generic successfully initialized and connected.
    [ 15.645000] it913x: DEV registering device driver
    [ 15.646000] usbcore: registered new interface driver it913x
    [ 18.190000] enter base init, xvd 20100413, vdc 20100413, rap 20100719, xpt 20110228
    [ 18.675000] 18:674998532 SMCA: controller reset timed out
    [ 18.685000] 18:685004596 SMCB: controller reset timed out
    [ 19.331000] register adapter
    [ 19.332000] register adapter
    [ 19.333000] register adapter
    [ 19.334000] register adapter
    [ 19.346000] FP Version 3
    [ 19.347000] input: dreambox front panel as /devices/virtual/input/input1
    [ 19.353000] set sb to 3(2)
    [ 19.354000] set fb to 2(-1)
    [ 19.354000] set input to 0
    [ 19.357000] bcm_video_analog_port_setup (fmt=7)
    [ 19.358000] SET FORMAT: display[1], format=7
    [ 19.359000] display 0 uses vbi path 1
    [ 19.359000] display 1 uses vbi path 0
    [ 19.360000] HDMI: now connected
    [ 19.395000] HDMI: EDID read ok
    [ 19.396000] HDMI: initial mode set!
    [ 19.396000] using 50.00Hz as MonitorRefreshRate
    [ 19.397000] SET FORMAT: display[0], format=37
    [ 19.397000] HDMI mode
    [ 19.397000] use EDID to detect colorspace
    [ 19.398000] using colorspace: 1
    [ 19.427000] HDMI: use logical CEC address 3
    [ 19.471000] set fb to 2(0)
    [ 19.471000] bcm_video_analog_port_setup (fmt=7)
    [ 19.471000] SET FORMAT: display[1], format=7
    [ 19.479000] disable wss on display 0
    [ 19.479000] disable wss on display 1
    [ 19.480000] bcmfb: creating surface with pixel format 0x07e48888 (BPXL_eA8_R8_G8_B8)
    [ 19.564000] CEC send ok!
    [ 19.617000] enable mad
    [ 19.659000] VIDEO0: set fallback framerate to 60000
    [ 19.660000] VIDEO0: set progressive override mode to 1
    [ 19.660000] VIDEO0: set streamtype!
    [ 19.661000] set MPEG2
    [ 19.661000] sw rave disabled!
    [ 19.665000] sync is off so we enable it
    [ 19.666000] playback!
    [ 19.666000] total video delay: 0 (0 ms)
    [ 19.669000] VIDEO0: start decode
    [ 19.670000] flush video decoder
    [ 19.670000] VIDEO0 got pts failed !!!! (ret 0)
    [ 21.069000] set ac3 to downmix
    [ 21.069000] set ac3plus to use_hdmi_caps
    [ 21.070000] set aac to downmix
    [ 21.070000] init ALSA!
    [ 21.099000] VIDEO0: first pts 0x0
    [ 21.130000] DVB: registering new adapter (BCM7405)
    [ 21.155000] autodetecting NIMs...
    [ 21.155000] slot 0
    [ 21.157000] ret: 2, feid: 13
    [ 21.158000] Found: Slot 0, ID: 13 (by CA)
    [ 21.159000] Initializing adapter 0 (BCM4505-DVB-S2)
    [ 21.218000] bcm4506: found 4505, revision 0(b0)
    [ 21.219000] bcm4506: bcm_initAP
    [ 21.225000] bcm4506: upload & start firmware
    [ 21.249000] enable tsm0
    [ 23.246000] bcm4506: bcm4506: ap not running - start now
    [ 23.294000] bcm4506: uCode 0x61
    [ 23.311000] bcm4506: no bcm3445 detected
    [ 23.326000] DVB: registering adapter 1 frontend 0 (bcm4506)...
    [ 24.539000] VIDEO0: stop decode
    [ 24.540000] no decoder left in sync handling so disable xpt_sync
    [ 24.543000] registered vtuner misc/vtuner0, minor 56
    [ 24.544000] registered vtuner misc/vtuner1, minor 55
    [ 27.552000] input: dreambox remote control (native) as /devices/virtual/input/input2
    [ 27.554000] input: dreambox advanced remote control (native) as /devices/virtual/input/input3
    [ 27.563000] input: dreambox ir keyboard as /devices/virtual/input/input4
    [ 27.565000] input: dreambox ir mouse as /devices/virtual/input/input5
    [ 27.578000] 4022545 ms:
    [ 27.664000] 85 ms: 14
    [ 28.261000] kjournald starting. Commit interval 5 seconds
    [ 28.262000] EXT3-fs (sda1): using internal journal
    [ 28.263000] EXT3-fs (sda1): mounted filesystem with writeback data mode
    [ 28.326000] kjournald starting. Commit interval 5 seconds
    [ 28.326000] EXT3-fs (sda2): warning: maximal mount count reached, running e2fsck is recommended
    [ 28.326000] EXT3-fs (sda2): using internal journal
    [ 28.326000] EXT3-fs (sda2): mounted filesystem with writeback data mode
    [ 28.340000] 675 ms: 16
    [ 28.863000] 523 ms: 18
    [ 28.932000] 68 ms: 20
    [ 28.978000] 45 ms: 22
    [ 31.949000] 2971 ms: 24
    [ 31.991000] 42 ms: 26
    [ 32.063000] 72 ms: 28
    [ 32.112000] 49 ms: 30
    [ 32.578000] 466 ms: 33
    [ 32.699000] 121 ms: 34
    [ 33.651000] 951 ms: 36
    [ 33.753000] 102 ms: 37
    [ 33.812000] 59 ms: 39
    [ 33.863000] 50 ms: 41
    [ 33.959000] 96 ms: 42
    [ 34.089000] 130 ms: 44
    [ 34.347000] 257 ms: 46
    [ 34.381000] 33 ms: 47
    [ 46.807000] bcm4506: channel 0 is in normale mode now
    [ 46.821000] bcm4506: channel 0 is sleeping now
    [ 46.826000] bcmfb: enable manual blit
    [ 46.856000] bcmfb: creating surface with pixel format 0x07e48888 (BPXL_eA8_R8_G8_B8)
    [ 47.743000] 13362 ms: 49
    [ 47.773000] 30 ms: 50
    [ 47.808000] 35 ms: 50
    [ 47.816000] 8 ms: 50
    [ 49.651000] 1835 ms: 50
    [ 51.217000] 1565 ms: 53
    [ 51.245000] 27 ms: 56
    [ 51.334000] 88 ms: 56
    [ 51.399000] 64 ms: 57
    [ 51.402000] 2 ms: 57
    [ 51.486000] 84 ms: 57
    [ 51.781000] 295 ms: 57
    [ 51.917000] 136 ms: 57
    [ 51.949000] 32 ms: 58
    [ 51.951000] 1 ms: 58
    [ 51.953000] 1 ms: 58
    [ 52.298000] 345 ms: 58
    [ 52.301000] 2 ms: 58
    [ 52.428000] 127 ms: 59
    [ 52.781000] 352 ms: 59
    [ 52.783000] 1 ms: 59
    [ 52.806000] 22 ms: 59
    [ 52.834000] 27 ms: 60
    [ 52.836000] 1 ms: 60
    [ 52.849000] 12 ms: 60
    [ 52.890000] 40 ms: 60
    [ 53.942000] 1052 ms: 60
    [ 53.972000] 30 ms: 62
    [ 53.994000] 22 ms: 62
    [ 54.013000] 18 ms: 62
    [ 54.043000] 29 ms: 62
    [ 54.085000] 42 ms: 62
    [ 54.087000] 2 ms: 62
    [ 54.090000] 3 ms: 62
    [ 54.114000] 24 ms: 62
    [ 56.217000] 2103 ms: 62
    [ 56.304000] 86 ms: 66
    [ 56.561000] 257 ms: 66
    [ 56.765000] 204 ms: 67
    [ 56.767000] 1 ms: 67
    [ 56.814000] 46 ms: 67
    [ 56.817000] 3 ms: 67
    [ 56.820000] 3 ms: 67
    [ 56.825000] 5 ms: 67
    [ 56.844000] 19 ms: 67
    [ 56.874000] 29 ms: 67
    [ 56.902000] 28 ms: 68
    [ 56.971000] bcmfb: creating surface with pixel format 0x07e48888 (BPXL_eA8_R8_G8_B8)
    [ 57.213000] 310 ms: 68
    [ 57.349000] 135 ms: 68
    [ 57.399000] set current avs auto aspect to 4:3
    [ 57.399000] disable wss on display 0
    [ 57.400000] disable wss on display 1
    [ 57.400000] set sb to 3(2)
    [ 57.439000] set current avs auto aspect to 4:3
    [ 57.439000] disable wss on display 0
    [ 57.440000] disable wss on display 1
    [ 57.440000] set sb to 3(2)
    [ 57.442000] disable wss on display 0
    [ 57.443000] set wss 8 on display 1
    [ 57.481000] set input to 0
    [ 57.481000] set fb to 2(0)
    [ 57.482000] set current avs auto aspect to 4:3
    [ 57.482000] disable wss on display 0
    [ 57.483000] set wss 8 on display 1
    [ 57.485000] set sb to 3(2)
    [ 57.487000] set ac3 to downmix
    [ 57.490000] set ac3plus to use_hdmi_caps
    [ 57.497000] 148 ms: 68
    [ 57.538000] 41 ms: 69
    [ 57.552000] 13 ms: 69
    [ 57.850000] 298 ms: 69
    [ 57.854000] 3 ms: 69
    [ 57.903000] 49 ms: 69
    [ 61.719000] set current avs auto aspect to 16:9
    [ 61.719000] disable wss on display 0
    [ 61.720000] set wss 7 on display 1
    [ 61.721000] set sb to 3(1)
    [ 61.819000] set current avs auto aspect to 16:9
    [ 61.819000] disable wss on display 0
    [ 61.820000] set wss 7 on display 1
    [ 61.821000] disable wss on display 0
    [ 61.822000] set wss 7 on display 1
    [ 61.823000] set current avs auto aspect to 16:9
    [ 61.824000] disable wss on display 0
    [ 61.824000] set wss 7 on display 1
    [ 61.825000] set sb to 3(1)
    [ 61.829000] set current avs auto aspect to 16:9
    [ 61.830000] disable wss on display 0
    [ 61.830000] set wss 7 on display 1
    [ 61.831000] set sb to 3(1)
    [ 61.832000] set current avs auto aspect to 16:9
    [ 61.833000] disable wss on display 0
    [ 61.833000] set wss 7 on display 1
    [ 61.834000] set sb to 3(1)
    [ 61.835000] disable wss on display 0
    [ 61.835000] set wss 7 on display 1
    [ 61.837000] set current avs auto aspect to 16:9
    [ 61.837000] disable wss on display 0
    [ 61.838000] set wss 7 on display 1
    [ 61.838000] set sb to 3(1)
    [ 61.843000] set current avs auto aspect to 16:9
    [ 61.844000] disable wss on display 0
    [ 61.844000] set wss 7 on display 1
    [ 61.845000] set sb to 3(1)
    [ 61.847000] set current avs auto aspect to 16:9
    [ 61.847000] disable wss on display 0
    [ 61.848000] set wss 7 on display 1
    [ 61.848000] set sb to 3(1)
    [ 61.850000] disable wss on display 0
    [ 61.850000] set wss 7 on display 1
    [ 61.852000] set current avs auto aspect to 16:9
    [ 61.852000] disable wss on display 0
    [ 61.853000] set wss 7 on display 1
    [ 61.854000] set sb to 3(1)
    [ 61.861000] set current avs auto aspect to 16:9
    [ 61.862000] disable wss on display 0
    [ 61.863000] set wss 7 on display 1
    [ 61.863000] set sb to 3(1)
    [ 61.864000] set current avs auto aspect to 16:9
    [ 61.865000] disable wss on display 0
    [ 61.865000] set wss 7 on display 1
    [ 61.866000] set sb to 3(1)
    [ 61.867000] disable wss on display 0
    [ 61.867000] set wss 7 on display 1
    [ 61.869000] set current avs auto aspect to 16:9
    [ 61.869000] disable wss on display 0
    [ 61.870000] set wss 7 on display 1
    [ 61.870000] set sb to 3(1)
    [ 61.879000] using 50.00Hz as MonitorRefreshRate
    [ 61.979000] SET FORMAT: display[0], format=27
    [ 61.979000] HDMI mode
    [ 61.980000] use EDID to detect colorspace
    [ 61.980000] using colorspace: 1
    [ 62.060000] bcm_video_analog_port_setup (fmt=7)
    [ 62.179000] SET FORMAT: display[1], format=7
    [ 62.299000] set current avs auto aspect to 16:9
    [ 62.300000] disable wss on display 0
    [ 62.300000] set wss 7 on display 1
    [ 62.302000] set current avs auto aspect to 16:9
    [ 62.302000] disable wss on display 0
    [ 62.303000] set wss 7 on display 1
    [ 62.304000] set sb to 3(1)
    [ 62.334000] set current avs auto aspect to 16:9
    [ 62.334000] disable wss on display 0
    [ 62.335000] set wss 7 on display 1
    [ 62.335000] set sb to 3(1)
    [ 62.337000] set current avs auto aspect to 16:9
    [ 62.338000] disable wss on display 0
    [ 62.338000] set wss 7 on display 1
    [ 62.339000] set sb to 3(1)
    [ 62.340000] disable wss on display 0
    [ 62.341000] set wss 7 on display 1
    [ 62.343000] set current avs auto aspect to 16:9
    [ 62.343000] disable wss on display 0
    [ 62.344000] set wss 7 on display 1
    [ 62.344000] set sb to 3(1)
    [ 70.591000] 12688 ms: 69
    [ 70.628000] 37 ms: 95
    [ 70.641000] 13 ms: 95
    [ 72.696000] 2055 ms: 95
    [ 72.814000] 118 ms: 99
    [ 72.898000] 84 ms: 99
    [ 72.911000] 12 ms: 99
    [ 74.881000] CEC send ok!
    [ 75.312000] CEC send ok!
    [ 75.427000] CEC send ok!
    [ 75.616000] CEC recv ok!
    [ 75.703000] CEC send ok!
    [ 138.157000] CEC recv ok!
    [ 139.889000] CEC recv ok!
    root@dm800se:~# lsmod
    Module Size Used by Tainted: P
    autofs4 25216 1
    dreambox_keyboard 3296 0
    dreambox_rc2 5216 1 dreambox_keyboard
    bcm7405 3937366 5
    alps_bsbe2 42739 1 bcm7405
    snd_pcm 64308 1 bcm7405
    snd_timer 19010 1 snd_pcm
    snd_page_alloc 5453 1 snd_pcm
    tmp100 910 1 bcm7405
    tu1216 40318 1 bcm7405
    cu1216mk3 7914 1 bcm7405
    alps_bsbe1_c01a 17032 1 bcm7405
    si2169c 516025 1 bcm7405
    si2166b 104624 1 bcm7405
    bcm4506 91738 1 bcm7405
    helper 540 1 bcm7405
    cxd1981 14278 1 bcm7405
    alps_bsbe1 6195 1 bcm7405
    lnb_ctrl 6963 5 alps_bsbe2,alps_bsbe1_c01a,si2166b,bcm4506,alps_bs be1
    stv0299 9368 1 alps_bsbe1
    lcd 43577 1
    stb_core 16770 13 dreambox_keyboard,dreambox_rc2,bcm7405,alps_bsbe2, tmp100,cu1216mk3,alps_bsbe1_c01a,si2169c,si2166b,b cm4506,cxd1981,lnb_ctrl,lcd
    dvb_usb_it913x 9650 0
    it913x_fe 12483 1 dvb_usb_it913x
    dvb_usb 17648 1 dvb_usb_it913x
    rc_core 13858 3 dvb_usb_it913x,dvb_usb
    root@dm800se:~# lsusb
    Bus 001 Device 001: ID 1d6b:0002
    Bus 002 Device 001: ID 1d6b:0002
    Bus 003 Device 001: ID 1d6b:0001
    Bus 004 Device 001: ID 1d6b:0001
    Bus 001 Device 002: ID 048d:9135
    root@dm800se:~#
    It seems ok, doesn-t it ? Why the second tuner is NOT added then ?
    thanks in advance
