Remote 2 - 5200 super
  • jc2
    Anyone know what the remote 2 does in the menu???
    I have two recivers the same and currently cover one IR reciever to be able to use the other , can I use this setting to switch between 2 remotes?????
    JC
  • dick b
    • Jun 2009
    • 2462
    as far as I understand it the remote type is paired to the box so if both boxes need type 2 thats it you cant change any settings for it.and if you change the type in the menu it wont work.
    • Manic01
      • 5117
      There were 2 different remotes, if you select remote type 2 when it is remote type 1 you need you only get limited functions.
      They ar eboth the same IR.
