Hi, i was thinking of putting my technomate 1500 to some use, i believe there are some channels open on bullsat, bit confused as to where that is? i only have a fixed dish, my setup is working ok as i had a fiddle with it today on astra and hotbird, could anyone give me some advise to get that sat. Thanks.
bullsat
as above and www.dishpointer .com will show you the direction to point the dish and the lnb skew needed on a fixed dish.Comment
bullsat
Thanks for replies, had a good go at getting that satellite today, but could not get it, i think my line of sight is slightly blocked by the corner of a neighbours house, tried raising the dish a bit, as it is in my garden, no trees or anything else in the way, i have a 80cm dish and could get all other usual sats, hotbird astra etc, only way i did this once before was thor on a mates setup, i got round this by loading the channels at my home on his technomate and then take the box to his home, maybe that would work for this sat?Comment
Any chance you can explain how you do this?
I have downloaded the latest tmsoftcam bullsat keys and can open some of the channels listed (Rai4, TV Global) but those I really want are on Hellassat (Nova Sport)
Cheers mateComment
Unfortunately still scrambled. Which patch are you using?
I'm on Phantom PatchComment
Working!!
This thread Nova Sport sorted me out.
As soon as I changed motorised settings from to USALS, the TP address appeared and Nova Sport BG appeared!
39 deg
I am still unsure how to lock on to 39deg, if i can't lock on to this satellite how can i search for a strong channel? had another go today but no luck, i think it would be easier with a motorised setup which i have done before for a friend, or am i doing something wrong? any advice would be appreciated. Thanks.Comment
Remember to skew the LNB .I am still unsure how to lock on to 39deg, if i can't lock on to this satellite how can i search for a strong channel? had another go today but no luck, i think it would be easier with a motorised setup which i have done before for a friend, or am i doing something wrong? any advice would be appreciated. Thanks.
I had trouble until someone(dick) reminded me it needed skewing,boom strong signal.....look at all the sly dish LNBs near by you ll see they are skewed,do it in the same direction and a little bit more,GLSpiderbox ,1m motorised dish...Comment
