Bulsat settings
  • Redmanc
    • Oct 2011
    • 26
    Bulsat settings
    Hiya, An new to all this techno stuff,Don,t know a thing about satellites or the jargon what goes with it! so please be gentle
    I have bought and already been told (i have let people down ) By buying my motorised dish and Tm-5402HD C+ Super from what you call a payserver scumbag! Told you i know nothing, BUT i am willing to learn with your help? i have 13.0E Hotbird, 16.0E Eutelsat W2 and 28.2E Astra 2/Eurobird and i don,t want to lose these has i have my programmes on them from the scumbag!!!!
    I will to learn in stupid layman terms how to tune my receiver into receiving Bulsat and any other english speaking satellites that may be good for us. My mate is bulgarian and i watched the channels at his home in spain. I know that that theres enough english speaking stuff on there for my family to watch.
    I know i need to press the menu button and go to the advance search bit.
    The page looks like this? Please fill in gaps Thank you
    Satellite .........East or......... west
    Transponder.....................
    Symbol rate.......................
    Polarization........................
    Search Type.........................
    Network Search..............................
    At the botom of the page theres a (red) scan button and a (green) add TP button, Which one do i press? if any
    Also do i need to buy a CONEX card to put in my receiver? Thank you guys
  • dick b
    • Jun 2009
    • 2462
    to get 39E on your box.menu>satellite setup>press OK twice this will bring a drop down sub menu up scroll through them til you find 39E hellasat press yellow button to put a tick against it then exit,exit.go to motorised settings make sure 39E is on top line then drop to "go to" line >ok when motor stops scan and you should have it,
    • Redmanc
      • Oct 2011
      • 26
      I have done everything you have said, But after the scan it found 39 channels! None of them are working?
      Please if anyone has any other ideas on how i can get bulsat in simple terms please help. Many thanks
      • dick b
        • Jun 2009
        • 2462
        [QUOTE=Redmanc;1310279]I have done everything you have said, But after the scan it found 39 channels! None of them are working?
        Please if anyone has any other ideas on how i can get bulsat in simple terms please help. Many thanks[/QUOTE
        do you have a channel called"the voice" its a FTA music channel on transponder 12.524 H 30000.name some of the channels you get they may have $ signs against them if they are encrypted.
        I cant advise about cards as I dont use them but others will.
        is your box setup for usals?go to the motorised settings menu and next to "diseqc motor" it will either read 1.2 or usals (it cant read off if the motors working)
        • Redmanc
          • Oct 2011
          • 26
          Hiya Dick
          No i don,t have the voice am afraid!
          Yes i have the technomate 5402HD Cl+
          your right the channels its found have all got the encryption signs
          My box does show usals when am on the motorised settings page! Many thanks for your help!
          Sorry for being a pain
          Do i need to insert cards or something?
          I feel so useless
          • thijs
            • Apr 2010
            • 1096
            what kind of a scan did you do on 39 east
            did you try blindscan or scan with networksearch on?
            this should get you more channels.
            Everything discussed on this forum is for experimental and educational purposes only. Use the information at your own risk.
            • dick b
              • Jun 2009
              • 2462
              your not a pain mate and we will help if we can.
              It will help if you name some of the channels you have found encrypted or not.
              • Redmanc
                • Oct 2011
                • 26
                I just pressed the scan button on the bottom (RED)
                Which do i need to do?
                • Redmanc
                  • Oct 2011
                  • 26
                  All encrypted Dick!
                  Rts1
                  Rts 2
                  Arena sport 1
                  Arena sport 2
                  Arena sport 3
                  Arena sport 4
                  Tv zajecar
                  Prva
                  Rtv novi pazi
                  happy Tv
                  Discovery serbia
                  HBo
                  Bulgaria on air
                  Have i scanned it wrong or something? Cheers
                  • Manic01
                    • 5117
                    Heres full satellite list for bulsat 39e
                    Only Irdeto 2 Channels clear.
                    Packages: Bulsatcom - KingOfSat
                    • dick b
                      • Jun 2009
                      • 2462
                      you are on the right sat by the look of it you need to scan the following Transponders for whats open on bulsat.
                      12.524 H,12.565H,12.688H,all 30000 sym rate . go to the advanced search menu and scroll through the TPs and scan as you find them if they are missing you can "add TP".for them to open you will need the right patch installed and the latest softcam. I dont know your model but others will for the right patch.
                      • Nutsandbolts
                        • Oct 2011
                        • 1168
                        Hi. I think you have an alignment problem if you are only getting some channels. I had similar problems awhile back with this satellite. USALS would send it to this satellite but i was unable to get IRDETO 2 channels like DIEMA and NOVASPORT. I had to manually adjust the dish a fraction and the channels appeared. I then tightened the dish up. The problem that people have with this satellite is the tilt of the dish. The way the motor works is that when it moves from WEST to EAST the dish gradually lowers and tilts itself. I suspect that you also have problems with the TURKSAT satellite next door like i had. Also check your LNB mounting as if this is slightly out it can also give you signal problems. Regarding scanning it always best to use the BLIND SEARCH option because it will scan for frequencies which are not in your receiver memory.
                        • Redmanc
                          • Oct 2011
                          • 26
                          Thank you so much for all your input! very much appreciated. I will try the advance stage thing and report back! Thank you
                          Oh by the way i have the technomate 5402HD Cl+
                          Do i need patches or latest softcam?
                          Am sorry i don,t know what either of theses things are?
                          • thijs
                            • Apr 2010
                            • 1096
                            you would need latest patch Download center and latest softcam found in tmsoftcam section Softcam Keys patch makes your tm able to use the hack for the providers and softcam would have the keys to open the scrambled channels and they can change evry so many days or sometimes weeks.so always load the latest softcam with updated keys to your tm and if you load the latest addon to your tm Download center you can also use it for cccam (cardshare)
                            • Redmanc
                              • Oct 2011
                              • 26
                              Thank you thijs
                              How do i download the patches and cams and on to what?
                              Sorry guys but i am learning! I have now managed to get over 130 channels on 39E, But as i said all scrambled
