TM-9100 Info needed
  • ryan8188
    • 174
    TM-9100 Info needed
    Just wondering what the tm 9100 is like. Can you put the same images on it as a dm500 as its linux based.
    It seems better than a dm500 as it has a ci slot and option for a hdd to use it as a pvr. Is this the case.
    Would anyone recommend this receiver or would you stick with the dm500. I just want somthing thats linux based so you can use cccam etc plus has the option of a ci slot and pvr option. Which isnt too pricey.
    cheers
  • billy2
    • 1381
    The 9100 is very similar to a dreambox 7020
    please press the little red THANKS tab
    if I helped if not press the green tab to tell me to f**Koff
